Hallo, nach dem absenden der Bestellung kommt folgende Fehlermeldung: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Syntax Error in template „string:“ on line 48 " {if additional.payment.name == \"debit\"} " - Unexpected "\", expected one of: "{" , "" , „identifier“ , LDELIF , LDELFOR , LDELFOREACH , „closing tag“ , INTEGER , „+“ , „-“ , „(“ , „(!,not)“ , TYPECAST , HEX , „.“ , SINGLEQUOTESTRING , „#“ , „[“ , „“" in Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php on line 404 Stack trace: #0 Vendor/Smarty/libs/sysplugins/smarty_internal_templateparser.php(2699): Smarty_Internal_TemplateCompilerBase->trigger_template_error() #1 Vendor/Smarty/libs/sysplugins/smarty_internal_templateparser.php(2764): Smarty_Internal_Templateparser->yy_syntax_error(10, ‚‘) #2 Vendor/Smarty/libs/sysplugins/smarty_internal_smartytemplatecompiler.php(51): Smarty_Internal_Templateparser->doParse(10, ‚‘) #3 Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php(83): Smarty_Internal_SmartyTemplateCompiler->doCompile(’
compileTemplate(Object(Enlight_Template_Template)) #5 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(426): Smarty_Internal_Template->compileTemplateSource() #6 Enlight/Template/Template.php(46): Smarty_Internal_Template->renderTemplate() #7 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(568): Enlight_Template_Template->renderTemplate() #8 Vendor/Smarty/libs/Smarty.class.php(328): Smarty_Internal_Template->getRenderedTemplate() #9 engine/core/class/sOrder.php(915): Smarty->fetch('string:
sendMail(Array) #11 Shopware/Controllers/Frontend/Checkout.php(401): sOrder->sSaveOrder() #12 Shopware/Controllers/Frontend/Checkout.php(127): Shopware_Controllers_Frontend_Checkout->saveOrder() #13 Enlight/Controller/Action.php(55): Shopware_Controllers_Frontend_Checkout->finishAction() #14 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‚finishAction‘) #15 Enlight/Controller/Front.php(88): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #16 Shopware/Bootstrap.php(21): Enlight_Controller_Front->dispatch() #17 Enlight/Application.php(69): Shopware_Bootstrap->run() #18 shopware.php(6): Enlight_Application->run() #19 {main} hat jemand eine Idee wie ich das lösen kann?
