Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Zend_Session::start() - /kunden/xxxx/shop/engine/Enlight/Enlight/Zend/Session.php(Line:489): Error #8 session_start() [function.session-start]: ps_files_cleanup_dir: opendir(/tmp) failed: Permission denied (13) Array in Enlight/Zend/Session.php on line 513 Stack trace: #0 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(56): Zend_Session::start(Array) #1 [internal function]: Shopware_Plugins_Backend_Auth_Bootstrap::onInitResourceAuth(Object(Enlight_Event_EventArgs)) #2 Enlight/Event/EventHandler.php(60): call_user_func(‘Shopware_Plugin…’, Object(Enlight_Event_EventArgs)) #3 Enlight/Event/EventManager.php(96): Enlight_Event_EventHandler->execute(Object(Enlight_Event_EventArgs)) #4 Enlight/Bootstrap.php(179): Enlight_Event_EventManager->notifyUntil(‘Enlight_Bootstr…’, Array) #5 Enlight/Bootstrap.php(124): Enlight_Bootstrap->loadResource(‘Auth’) #6 Enlight/Application.php(396): Enlight_Bootstrap->hasResource(‘Auth’) #7 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(219): Enlight_Application->__call(‘Auth’, Array) #8 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(219): Shopware->Auth() #9 [internal function]: Shopware_Plugins_Backend_Auth_Bootstrap::onPreDispatchBackend(Object(Enlight_Event_EventArgs)) #10 Enlight/Event/EventHandler.php(60): call_user_func(‘Shopware_Plugin…’, Object(Enlight_Event_EventArgs)) #11 Enlight/Event/EventManager.php(70): Enlight_Event_EventHandler->execute(Object(Enlight_Event_EventArgs)) #12 Enlight/Controller/Action.php(63): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Array) #13 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‘getListAction’) #14 Enlight/Controller/Front.php(99): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #15 Shopware/Bootstrap.php(33): Enlight_Controller_Front->dispatch() #16 Enlight/Application.php(86): Shopware_Bootstrap->run() Bitte beheben Sie den Fehler oder löschen Sie das fehlerhafte Plugin! Gruß Rainer
Hallo Rainer, fehlen hier die Schreibrechte auf den tmp Ordner? MfG Frank
Hi, ich habe kein /tmp Verzeichnis! Viele Grüße Rainer
wie hast du das problem gelöst? ist bei mir auch aufgetaucht als ich mich im backend einlochen wollte
Wurde irgendein neues Plugin installiert? Ansonsten wurde hier im Forum folgende Lösung vorgeschlagen: administration-f11/plugins-konnen-nicht-im-backend-installiert-werden-fehler-t6737.html#p34929
