Hallo zusammen, kennt jemand diesen Fehler und auch die Abhilfe: [quote] Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Unknown column type “” requested. Any Doctrine type that you use has to be registered with \Doctrine\DBAL\Types\Type::addType(). You can get a list of all the known types with \Doctrine\DBAL\Types\Type::getTypesMap(). If this error occurs during database introspection then you might have forgot to register all database types for a Doctrine Type. Use AbstractPlatform#registerDoctrineTypeMapping() or have your custom types implement Type#getMappedDatabaseTypes(). If the type name is empty you might have a problem with the cache or forgot some mapping information. in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 183 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Types/Type.php(170): Doctrine\DBAL\DBALException::unknownColumnType(NULL) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(250): Doctrine\DBAL\Types\Type::getType(NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ArrayHydrator.php(111): Doctrine\ORM\Internal\Hydration\AbstractHydrator->gatherRowData(Array, Array, Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ArrayHydrator.php(97): Doctrine\ORM\Internal\Hydration\ArrayHydrator->hydrateRowData(Array, Array, Array) #4 vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(140): Doctrine\ORM\Internal\Hydration\ArrayHydrator->hydrateAllData() #5 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(804): Doctrine\ORM\Internal\Hydration\AbstractHydrator->hydrateAll(Object(PDOStatement), Object(Doctrine\ORM\Query\ResultSetMapping), Array) #6 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(586): Doctrine\ORM\AbstractQuery->execute(NULL, 2) #7 Shopware/Controllers/Widgets/Emotion.php(44): Doctrine\ORM\AbstractQuery->getArrayResult() #8 Shopware/Controllers/Widgets/Emotion.php(122): Shopware_Controllers_Widgets_Emotion->getEmotion(Object(Shopware_Proxies_ShopwareModelsEmotionRepositoryProxy)) #9 Enlight/Controller/Action.php(159): Shopware_Controllers_Widgets_Emotion->indexAction() #10 Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘indexAction’) #11 Enlight/Template/Plugins/function.action.php(96): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #12 cache/templates/frontend_emotion_green_de_DE_1/ab/12/67/ab126788ecfaa3dfe3f9e2cd2e615848476b2e19.snippet.index.tpl.php(483): smarty_function_action(Array, Object(Enlight_Template_Default)) #13 Smarty/sysplugins/smarty_internal_templatebase.php(180): content_540ef60bc15f16_69559252(Object(Enlight_Template_Default)) #14 Enlight/View/Default.php(273): Smarty_Internal_TemplateBase->fetch() #15 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default)) #16 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #17 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #18 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs)) #19 Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs)) #20 Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #21 Enlight/Controller/Action.php(202): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_ActionEventArgs)) #22 Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘indexAction’) #23 Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #24 Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #25 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #26 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #27 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #28 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #29 Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #30 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #31 Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #32 shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #33 {main} [/quote] Wir hatten den Fehler schon mal und damals war der Ion-Cube Loader noch nicht installiert. Den haben wir dann installiert und der FEhler war weg. Kennt jemand die Ursache? Danke und viele Grüße, Alex
