Fehler beim Update von 5.6.9 auf 5.7.6
ich versuche meinen Shop von 5.6.9 auf 5.7.6 upzudaten.
Leider erhalte ich nach dem Update bzw. während dem Aufräumen folgenden Fehler:
Slim Application Error
Type: ErrorException
Code: 256
Message: Listener "registerOmecoExternalSubscribers" in "OmecoPaymentShippingIcons" is not callable.
File: /var/www/.../web/engine/Library/Enlight/Event/Handler/Plugin.php
Line: 150
Trace
#0 [internal function]: Slim\Slim::handleErrors()
#1 /var/www/.../web/engine/Library/Enlight/Event/Handler/Plugin.php(150): trigger_error()
#2 /var/www/.../web/engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Plugin->execute()
#3 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(221): Enlight_Event_EventManager->notify()
#4 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(136): Shopware\Components\DependencyInjection\Container->doLoad()
#5 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Bridge/Front.php(65): Shopware\Components\DependencyInjection\Container->get()
#6 /var/www/.../web/var/cache/production_202110251506/proxies/ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer.php(5443): Shopware\Components\DependencyInjection\Bridge\Front->factory()
#7 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(257): ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer->getFrontService()
#8 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(231): Symfony\Component\DependencyInjection\Container->make()
#9 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(212): Symfony\Component\DependencyInjection\Container->get()
#10 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(136): Shopware\Components\DependencyInjection\Container->doLoad()
#11 /var/www/.../web/engine/Shopware/Bundle/MediaBundle/MediaService.php(296): Shopware\Components\DependencyInjection\Container->get()
#12 /var/www/.../web/engine/Shopware/Bundle/MediaBundle/MediaService.php(75): Shopware\Bundle\MediaBundle\MediaService->createFallbackMediaUrl()
#13 /var/www/.../web/engine/Shopware/Bundle/MediaBundle/MediaServiceFactory.php(85): Shopware\Bundle\MediaBundle\MediaService->__construct()
#14 /var/www/.../web/var/cache/production_202110251506/proxies/ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer.php(8052): Shopware\Bundle\MediaBundle\MediaServiceFactory->factory()
#15 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(257): ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer->getShopwareMedia_MediaServiceService()
#16 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(231): Symfony\Component\DependencyInjection\Container->make()
#17 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(212): Symfony\Component\DependencyInjection\Container->get()
#18 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(136): Shopware\Components\DependencyInjection\Container->doLoad()
#19 /var/www/.../web/var/cache/production_202110251506/proxies/ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer.php(9293): Shopware\Components\DependencyInjection\Container->get()
#20 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(257): ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer->getThemeServiceService()
#21 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(231): Symfony\Component\DependencyInjection\Container->make()
#22 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(212): Symfony\Component\DependencyInjection\Container->get()
#23 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(136): Shopware\Components\DependencyInjection\Container->doLoad()
#24 /var/www/.../web/var/cache/production_202110251506/proxies/ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer.php(9285): Shopware\Components\DependencyInjection\Container->get()
#25 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(257): ShopwareProduction61cff9cb7b7b6b2f139adb3dcfc66665d81164ebProjectContainer->getThemeInstallerService()
#26 /var/www/.../web/vendor/symfony/dependency-injection/Container.php(231): Symfony\Component\DependencyInjection\Container->make()
#27 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(212): Symfony\Component\DependencyInjection\Container->get()
#28 /var/www/.../web/engine/Shopware/Components/DependencyInjection/Container.php(136): Shopware\Components\DependencyInjection\Container->doLoad()
#29 /var/www/.../web/recovery/update/src/DependencyInjection/Container.php(189): Shopware\Components\DependencyInjection\Container->get()
#30 /var/www/.../web/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection\{closure}()
#31 /var/www/.../web/recovery/common/src/DependencyInjection/Container.php(73): Pimple\Container->offsetGet()
#32 /var/www/.../web/recovery/update/src/app.php(169): Shopware\Recovery\Common\DependencyInjection\Container->get()
#33 [internal function]: {closure}()
#34 /var/www/.../web/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array()
#35 /var/www/.../web/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#36 /var/www/.../web/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#37 /var/www/.../web/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#38 /var/www/.../web/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#39 /var/www/.../web/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#40 /var/www/.../web/recovery/update/index.php(57): Slim\Slim->run()
#41 {main}
Kann mir jemand einen Tipp geben?
Ich habe auch schon versucht Plugins, welcjhe kein Update mehr erhalten bzw. outdated sind zu deaktivieren vor dem Update aber auch das bringt keinen Erfolg.
Danke!
Weiß nicht um welches Plugin es sich genau handelt, aber von Shopware kommt das nicht. Muss ein Plugin sein. Irgendetwas mit „Omeco“ … mir sagt das aber nichts.
