Wir haben den Fehler auch in der Version 6.4.9.0 aber nur im Chrome Browser und auch in der neuen Version 6.4.10.0
Getestet in einer absolut frischem dockware play container ohne Plugins.
app.js?16488286896423139:1 An error was captured in current module: DOMException: Failed to execute ‚removeChild‘ on ‚Node‘: The node to be removed is not a child of this node.
at a.beforeUnmountedComponent (http://localhost/bundles/administration/static/js/app.js?16488286896423139:1:36564)
at a.beforeDestroyComponent (http://localhost/bundles/administration/static/js/app.js?16488286896423139:1:36234)
at a.beforeDestroy (http://localhost/bundles/administration/static/js/app.js?16488286896423139:1:35096)
at Ge (http://localhost/bundles/administration/static/js/vendors-node.js?16488286891570027:2:691220)
at ln (http://localhost/bundles/administration/static/js/vendors-node.js?16488286891570027:2:705225)
at a.e.$destroy (http://localhost/bundles/administration/static/js/vendors-node.js?16488286891570027:2:714609)
at destroy (http://localhost/bundles/administration/static/js/vendors-node.js?16488286891570027:2:700483)
at x (http://localhost/bundles/administration/static/js/vendors-node.js?16488286891570027:2:738252)
at x (http://localhost/bundles/administration/static/js/vendors-node.js?16488286891570027:2:738351)
errorCaptured @ app.js?16488286896423139:1
Xe @ vendors-node.js?16488286891570027:2
Ge @ vendors-node.js?16488286891570027:2
ln @ vendors-node.js?16488286891570027:2
e.$destroy @ vendors-node.js?16488286891570027:2
x @ vendors-node.js?16488286891570027:2
(anonymous) @ vendors-node.js?16488286891570027:2
w @ vendors-node.js?16488286891570027:2
A @ vendors-node.js?16488286891570027:2
e._update @ vendors-node.js?16488286891570027:2
i @ vendors-node.js?16488286891570027:2
xn.get @ vendors-node.js?16488286891570027:2
xn.run @ vendors-node.js?16488286891570027:2
yn @ vendors-node.js?16488286891570027:2
Promise.then (async)
qe @ vendors-node.js?16488286891570027:2
ot @ vendors-node.js?16488286891570027:2
xn.update @ vendors-node.js?16488286891570027:2
fe.notify @ vendors-node.js?16488286891570027:2
set @ vendors-node.js?16488286891570027:2
wn.set @ vendors-node.js?16488286891570027:2
onCloseSettingsModal @ app.js?16488286896423139:1
o._wrapper @ vendors-node.js?16488286891570027:2
Show 26 more frames
