ppeter
March 6, 2018, 1:37pm
1
Hallo!
hab diese Fehler Meldung nach diesem Befehl:
Error response from daemon: Container c44a5ecc13555573c168e01be1806461dc88ce7565f421221d0b419c65d33867 is not running
was wäre hier zu tun?
dank
elg
Peter
root@vps18066:~/shopware-docker# ./psh.phar docker:ssh
what is missing?
thx
Starting Execution of ‘docker:ssh’ (‘dev-ops/docker/actions/ssh.sh’)
(1/1) Starting
> docker exec -i -u 0:0 -t c44a5ecc13555573c168e01be1806461dc88ce7565f421221d0b419c65d33867 bash
Execution aborted, a subcommand failed!
Hey,
da hast du ein Problem mit Deinem Docker, dafür gibt’s eigene Foren (docker.com ). Die Fehlermeldung meint, was sie sagt, einer deiner Container ist nicht gestartet.
Viel Erfolg,
Geert
ppeter
March 6, 2018, 7:41pm
3
Hi, herzlichen dank, da frag ich gleich nach! lg Peter
ppeter
March 7, 2018, 6:50am
4
hab folgenden Fehler noch
(1/1) Starting
> docker exec -i -u 0:0 -t bash
“docker exec” requires at least 2 argument(s).
See ‘docker exec --help’.
Usage: docker exec [OPTIONS] CONTAINER COMMAND [ARG…]
Run a command in a running container
ppeter
5
root@vps18066:~/shopware-docker# docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
26bffe107cd5 shopwaredocker_app_es “/bin/bash bin/es-…” 22 hours ago Exited (1) 22 hours ago shopwaredocker_app_es_1
70c11866ffc1 shopwaredocker_app_redis “docker-entrypoint…” 22 hours ago Up 22 hours 6379/tcp shopwaredocker_app_redis_1
a87a353dcee9 shopwaredocker_app_mysql “docker-entrypoint…” 22 hours ago Up 22 hours 3306/tcp shopwaredocker_app_mysql_1
ppeter
March 7, 2018, 7:51am
6
debconf: delaying package configuration, since apt-utils is not installed
hatte fehler deshalb
useradd: UID 0 is not unique
chown: invalid user: ‘app-mysql:app-mysql’
passwd: user ‘app-mysql’ does not exist
—> Running in c013d6a618f3
debconf: unable to initialize frontend: Dialog
debconf: (TERM is not set, so the dialog frontend is not usable.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
und hab dann nachher immer den gleichen fehler
(1/1) Starting
> docker exec -i -u 0:0 -t f5640474fbd8a04030fc9f89b2b5533f2640a3175288831ea1b0d4530ffbd002 bash
Error response from daemon: Container f5640474fbd8a04030fc9f89b2b5533f2640a3175288831ea1b0d4530ffbd002 is not running
