sh: 1: docker-compose: not found - Execution aborted, a subcommand failed! - shopware docker -
Hello!
i have this error
did anyone know why?
thx
Peter
Starting Execution of ‘docker:start’ (‘dev-ops/docker/actions/start.sh’)
(1/6) Starting
> echo "COMPOSE_PROJECT_NAME: ${COMPOSE_PROJECT_NAME}"
(2/6) Starting
> dev-ops/docker/containers/scriptcreator.sh
    Created /root/shopware-docker/dev-ops/docker/containers/php7/createuser.sh
    Created /root/shopware-docker/dev-ops/docker/containers/mysql/createuser.sh
(3/6) Starting
> docker-compose build && docker-compose up -d
Have you installed docker-compose?
Hi, i take that steps here
how did i do that?
thx
Peter
Did you read this? Install Docker Compose | Docker Documentation
Hi!
ok now i know
apt install docker-compose
i will test and come back
thx
Peter
what should i choose
Configuration file ‘/etc/default/docker’
 ==> Modified (by you or by a script) since installation.
 ==> Package distributor has shipped an updated version.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer’s version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      Z     : start a shell to examine the situation
 The default action is to keep your current version.
*** docker (Y/I/N/O/D/Z) [default=N] ?
*** docker (Y/I/N/O/D/Z) [default=N] ? D
Progress: [91%] [######################################################…]
— /etc/default/docker 2018-03-05 09:36:23.719377993 +0100
+++ /etc/default/docker.dpkg-new        2017-05-04 23:36:17.000000000 +0200
@@ -1,9 +1,20 @@
-# This file is managed by Puppet and local changes
-# may be overwritten
+# Docker Upstart and SysVinit configuration file
-OPTIONS=" -H unix:///var/run/docker.sock --ip-forward=true --iptables=true --ip-masq=true"
+# THIS FILE DOES NOT APPLY TO SYSTEMD
+#   Please see the documentation for “systemd drop-ins”:
+#   Redirecting…
+# Customize location of Docker binary (especially for development testing).
+#DOCKERD="/usr/local/bin/dockerd"
+# Use DOCKER_OPTS to modify the daemon startup options.
+#DOCKER_OPTS="–dns 8.8.8.8 --dns 8.8.4.4"
+# If you need Docker to use an HTTP proxy, it can also be specified here.
+#export http_proxy=“http://127.0.0.1:3128/”
 # This is also a handy place to tweak where Docker’s temporary files go.
-# TMPDIR="/tmp/"
+#export DOCKER_TMPDIR="/mnt/bigdrive/docker-tmp"
(END
i choose
thank you done
(4/6) Starting
> wait
(5/6) Starting
> echo "All containers started successfully"
(6/6) Starting
> echo "Web server IP: http://10.100.111.46"
Duration: 9m 17s
All commands successfully executed!
next problem
execute
root@vps18066:~/shopware-docker# ./psh.phar docker:ssh
what is missing?
thx
Starting Execution of ‘docker:ssh’ (‘dev-ops/docker/actions/ssh.sh’)
(1/1) Starting
> docker exec -i -u 0:0 -t c44a5ecc13555573c168e01be1806461dc88ce7565f421221d0b419c65d33867 bash
    Error response from daemon: Container c44a5ecc13555573c168e01be1806461dc88ce7565f421221d0b419c65d33867 is not running
