Liebes Forum
ich habe eben folgende Fehlermeldung erhalten:
exception ‚PDOException‘ with message ‚SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‚)‘ at line 1‘ in /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Statement/Pdo.php:228
Stack trace:
#0 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Statement/Pdo.php(228): PDOStatement->execute(Array)
#1 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Statement.php(303): Zend_Db_Statement_Pdo->_execute(Array)
#2 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend_Db_Statement->execute(Array)
#3 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(‚SELECT * FROM b…‘, Array)
#4 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(96): Zend_Db_Adapter_Pdo_Abstract->query(‚SELECT * FROM b…‘, Array)
#5 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Adapter/Abstract.php(776): Enlight_Components_Db_Adapter_Pdo_Mysql->query(‚SELECT * FROM b…‘, Array)
#6 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Plugins/Community/Frontend/kkOptionPictures/Bootstrap.php(228): Zend_Db_Adapter_Abstract->fetchAssoc(‚SELECT * FROM b…‘)
#7 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Frontend_kkOptionPictures_Bootstrap->onPostDispatchDetail(Object(Enlight_Controller_ActionEventArgs))
#8 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#9 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(192): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#10 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚productQuickVie…‘)
#11 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#12 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#13 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#14 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#15 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(444): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#18 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#19 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#20 /var/www/vhosts/meinshop.de/httpdocs/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#21 {main}Next exception ‚Zend_Db_Statement_Exception‘ with message ‚SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‚)‘ at line 1‘ in /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Statement/Pdo.php:234
Stack trace:
#0 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Statement.php(303): Zend_Db_Statement_Pdo->_execute(Array)
#1 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend_Db_Statement->execute(Array)
#2 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(‚SELECT * FROM b…‘, Array)
#3 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(96): Zend_Db_Adapter_Pdo_Abstract->query(‚SELECT * FROM b…‘, Array)
#4 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Db/Adapter/Abstract.php(776): Enlight_Components_Db_Adapter_Pdo_Mysql->query(‚SELECT * FROM b…‘, Array)
#5 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Plugins/Community/Frontend/kkOptionPictures/Bootstrap.php(228): Zend_Db_Adapter_Abstract->fetchAssoc(‚SELECT * FROM b…‘)
#6 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Frontend_kkOptionPictures_Bootstrap->onPostDispatchDetail(Object(Enlight_Controller_ActionEventArgs))
#7 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#8 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(192): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#9 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚productQuickVie…‘)
#10 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#11 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#12 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#13 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#14 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(444): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#18 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#19 /var/www/vhosts/meinshop.de/httpdocs/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#20 {main}
2017-01-22T11:08:23.948906+0100
core
„uri“: „/detail/productQuickView/ordernumber/s20147.2?isXHR=1“,
„method“: „GET“,
„query“: {
„isXHR“: „1“,
„module“: „frontend“,
„controller“: „detail“,
„action“: „productQuickView“,
„ordernumber“: „s20147.2“
„post“:
No session data available
1
meinshop
Da scheint etwas mit einer „productQuickView“ zu sein. Im habe mal gegoogelt. Quick View scheint es als Plugin zu geben, ein solches Plugin habe ich aber nicht. Als eigenes Plugin sieht man in der Fehlermeldung kkOptionPictures. Kann es daran liegen ?
Was könnte das sein ?
Liebe Grüße
Kerstin
Aber es ist ja auch vieles andere erwähnt. Gibt es einen Hinweis darauf, dass es an dem Plugin liegt ?
