sitze jetzt schon einige Zeit an der Fehlersuche, habe sämtliche Threads dazu gewälzt und komme leider nicht wirklich weiter.
Hier die Fehlermeldung:
[2016-10-04 16:59:52] core.ERROR: exception 'Less_Exception_Compiler' with message 'error evaluating function `darken` The first argument to darken must be a color (did you forgot commas?) index: 5068' in /rootWebsite/vendor/oyejorge/less.php/lib/Less/Tree/Call.php:80 Stack trace:
#0 /rootWebsite/vendor/oyejorge/less.php/lib/Less/Tree/Expression.php(52): Less_Tree_Call->compile(Object(Less_Environment))
#1 /rootWebsite/vendor/oyejorge/less.php/lib/Less/Tree/Value.php(27): Less_Tree_Expression->compile(Object(Less_Environment))
#2 /rootWebsite/vendor/oyejorge/less.php/lib/Less/Tree/Rule.php(75): Less_Tree_Value->compile(Object(Less_Environment))
#3 /rootWebsite/vendor/oyejorge/less.php/lib/Less/Tree/Ruleset.php(94): Less_Tree_Rule->compile(Object(Less_Environment))
#4 /rootWebsite/vendor/oyejorge/less.php/lib/Less/Tree/Ruleset.php(94): Less_Tree_Ruleset->compile(Object(Less_Environment))
#5 /rootWebsite/vendor/oyejorge/less.php/lib/Less/Tree/Ruleset.php(94): Less_Tree_Ruleset->compile(Object(Less_Environment))
#6 /rootWebsite/vendor/oyejorge/less.php/lib/Less/Parser.php(198): Less_Tree_Ruleset->compile(Object(Less_Environment))
#7 /rootWebsite/engine/Shopware/Components/Theme/LessCompiler/Oyejorge.php(93): Less_Parser->getCss()
#8 /rootWebsite/engine/Shopware/Components/Theme/Compiler.php(212): Shopware\Components\Theme\LessCompiler\Oyejorge->get()
#9 /rootWebsite/engine/Library/Enlight/Template/Plugins/function.compileLess.php(62): Shopware\Components\Theme\Compiler->compileLess('1475592467', Object(Shopware\Models\Shop\Template), Object(Shopware\Models\Shop\DetachedShop))
#10 /rootWebsite/var/cache/production_201609201510/templates/frontend_Wsc_de_DE_1_secure/f4/2a/af/f42aaf01f0201186d2531a327c1be1b0f221a175.snippet.index.tpl.php(699): smarty_function_compileLess(Array, Object(Enlight_Template_Default))
#11 /rootWebsite/var/cache/production_201609201510/templates/frontend_Wsc_de_DE_1_secure/f4/2a/af/f42aaf01f0201186d2531a327c1be1b0f221a175.snippet.index.tpl.php(198): content_57f3aabf49d907_56564981(Object(Enlight_Template_Default))
#12 /rootWebsite/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(180): content_57f3aabfe7e755_83702687(Object(Enlight_Template_Default))
#13 /rootWebsite/engine/Library/Enlight/View/Default.php(274): Smarty_Internal_TemplateBase->fetch()
#14 /rootWebsite/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#15 /rootWebsite/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#16 /rootWebsite/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#17 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#18 /rootWebsite/engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs))
#19 /rootWebsite/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#20 /rootWebsite/engine/Library/Enlight/Controller/Action.php(202): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#21 /rootWebsite/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('indexAction')
#22 /rootWebsite/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#23 /rootWebsite/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#24 /rootWebsite/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#25 /rootWebsite/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#26 /rootWebsite/vendor/symfony/http-kernel/HttpCache/HttpCache.php(444): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#27 /rootWebsite/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#28 /rootWebsite/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#29 /rootWebsite/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #30 /rootWebsite/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#31 /rootWebsite/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#32 {main} [] {"uid":"db883f1"}
Die Fehlermeldung im Backend:
“Während der Bearbeitung von Shop “Deutsch” ist ein Fehler aufgetreten: error evaluating function darken The first argument to darken must be a color (did you forgot commas?) index: 5068”
Das Update lief wunderbar durch, nur das eigene Theme was auf dem Response-Theme beruht, läuft nicht durch. Auch die Einstellungen im Backend bei den Farb-Konfigurationen haben nichts gebracht. Hier habe ich alle @darken, etc. durch feste Farbwerte ersetzt. Am Theme selbst, welches vorher ohne Probleme lief und meines erachtens nach Anleitung “updatefähig” erstellt wurde, ist nichts verändert worden.
Für Hinweise wäre ich sehr dankbar.
Mersi im Voraus.
Sieht wieder alles so aus, wie ich mir das gewünscht habe. DANKE nochmal!
