Emails aus Plugin heraus verschicken
Hey alle zusammen,
ich arbeite gerade an einem Plugin, welches mir die Dokumente einer Bestellung per Email rausschicken kann. Nun geht keinerlei Email raus, aber ich hab leider auch keine Ahnung wie ich dem Problem so wirklich auf den Grund gehen kann.
Was mach ich bisher?
    public function sendDocumentsAction()
        $orderIds = json_decode($this->Request()->get('orderIds'));
        if ($orderIds && count($orderIds) == 0)
            return $this->View()->assign([
                'success' => false,
        $config = array('auth' => 'login',
            'username' => '',
            'password' => '',
            'port' => '465',
            'ssl' => 'ssl');
        $transport = new Zend_Mail_Transport_Smtp('', $config);
        // Zend_Mail::setDefaultTransport($transport);
         * @var \Enlight_Components_Mail $mail
        // Create a mail instance
        $mail = Shopware()->Mail();
        $mail->setBodyText('Blafasel');
        $mail->setFrom('bla@fasel.de', 'Blafasel');
        $mail->addTo('bla@fasel.de', 'Blafasel');
        $subject = "Blafasel for: ";
        // cycle through all orders
        foreach ($orderIds as $orderId)
            // create the document SQL
            $repository = $this->getRepository('Shopware\\Models\\Order\\Document\\Document');
            $builder = $repository->createQueryBuilder('document');
            $builder->select()
                ->where('document.orderId = :orderId AND (document.type = 1 OR document.type = 4)')
                ->setParameter('orderId', $orderId); // Order id
            // Get all documents for this order
             * @var \Shopware\Models\Order\Document\Document[] $documents
            $documents = $builder->getQuery()->getResult();
            if (!$documents) continue;
            // Get order number and add to subject
            $order = $documents[0]->getOrder();
            if ($order)
                $subject = $subject . " " . $order->getNumber() . "";
            // cycle through all documents
            foreach ($documents as $document)
                 * @var \Shopware\Models\Order\Document\Document $document
                $hash = $document->getHash();
                if ($hash)
                    $pdfPath = Shopware()->DocPath() . 'files/documents/' . $hash . '.pdf';
                    $pdfContent = file_get_contents($pdfPath);
                    if (false !== $pdfContent)
                        $attachment = new Zend_Mime_Part($pdfContent);
                        $attachment->type = 'application/pdf';
                        $attachment->disposition = Zend_Mime::DISPOSITION_ATTACHMENT;
                        $attachment->encoding = Zend_Mime::ENCODING_BASE64;
                        $attachment->filename = ($order? $order->getNumber() . ($document->getTypeId() == 1 ? '_Rechnung' : '_Stornorechnung') . '.pdf' : $hash . '.pdf'); // name of file
                        $mail->addAttachment($attachment);
                    else
                        $this->logError("The document with the ID " . $document->getId() . " could not be found.");
        $mail->setSubject($subject);
        try
            $mail->send($transport);
        catch (Exception $e)
            $this->logError('Could not send email '.$e);
Soweit so gut. Durchlaufen tut es, aber leider ohne Erfolg. Kann mir da vielleicht jemand helfen?
zum einen würde ich ein Maildokument beim Installieren des Plugins anlegen z.B. so:
     * @param InstallContext $context
    public function install(InstallContext $context)
        $mailTemplate = Shopware()->Models()->getRepository('Shopware\Models\Mail\Mail')->findOneBy(['name' => 'MAILNAME']);
        if (!$mailTemplate instanceof Mail) {
            $mailTemplateContent = file_get_contents( __DIR__. '/Resources/Mail/MEINMAILTEMPLATE.html');
            $mailTemplate = new Mail();
            $mailTemplate->setIsHtml(true);
            $mailTemplate->setName('ausgezeichnetorgEmail');
            $mailTemplate->setFromMail('{config name=mail}');
            $mailTemplate->setFromName('{config name=shopName}');
            $mailTemplate->setSubject('MEIN BETREFF');
            $mailTemplate->setContentHtml($mailTemplateContent);
            $mailTemplate->setMailtype(Mail::MAILTYPE_USER);
            try {
                /** @var ModelManager $entityManager */
                $entityManager = Shopware()->Models();
                $entityManager->persist($mailTemplate);
                $entityManager->flush();
            } catch (Exception $e) {
                $this->logger->addError($e->getMessage());
und dann die Mail einfach so verschicken:
    private function sendMail($recipient) {
        $mailTemplate = Shopware()->Models()->getRepository('Shopware\Models\Mail\Mail')->findOneBy(['name' => 'MEINEMAIL']);
            return;
        // set mail vars
        $vars = [
            'parameter' => [
        // build mail
        try {
            $mail = Shopware()->TemplateMail()->createMail($mailTemplate->getName(), $vars);
            $subject = $mail->getSubject();
            $mail->clearSubject();
            $mail->addTo($recipient);
            // send mail
            $mail->send();
so werden die Maileinstellungen von deinem Shopware benutzt und du kannst Parameter in die Mail schreiben und dein Code wird deutlich schmaler.
Grüße Lukaschel
Erstmal danke! Werde das mal ausprobieren!
Im Prinzip soll das Ganze einfach nur eine interne Geschichte sein, wo die Dokumente eben als Anhang an eine Email gehen. Daher bin ich gar nicht soweit gegangen, dass so „offiziell“ einzubinden.
