Hallo, ich habe versucht das Tutorial “Die neuen Einkaufswelten im Shopware 3.5 nutzen” durchzuarbeiten, bekomme aber im Contentbereich folgende Fehlermeldung: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Unkown resource type ‘parent’ in Vendor/Smarty/libs/sysplugins/smarty_internal_template.php on line 755 Stack trace: #0 Enlight/Template/Template.php(73): Smarty_Internal_Template->loadTemplateResourceHandler(‘parent’) #1 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(590): Enlight_Template_Template->loadTemplateResourceHandler(‘parent’) #2 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(102): Smarty_Internal_Template->parseResourceName(‘parent:frontend…’, ‘parent’, ‘frontend/home/i…’, NULL) #3 Vendor/Smarty/libs/sysplugins/smarty_internal_compile_extends.php(37): Smarty_Internal_Template->__construct(‘parent:frontend…’, Object(Enlight_Template_TemplateManager), Object(Enlight_Template_Template)) #4 Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php(260): Smarty_Internal_Compile_Extends->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), NULL, NULL, NULL) #5 Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php(114): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‘extends’, Array) #6 Vendor/Smarty/libs/sysplugins/smarty_internal_templateparser.php(2221): Smarty_Internal_TemplateCompilerBase->compileTag(‘extends’, Array) #7 Vendor/Smarty/libs/sysplugins/smarty_internal_templateparser.php(2656): Smarty_Internal_Templateparser->yy_r38() #8 Vendor/Smarty/libs/sysplugins/smarty_internal_templateparser.php(2756): Smarty_Internal_Templateparser->yy_reduce(38) #9 Vendor/Smarty/libs/sysplugins/smarty_internal_smartytemplatecompiler.php(51): Smarty_Internal_Templateparser->doParse(11, ‘??’) #10 Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php(83): Smarty_Internal_SmartyTemplateCompiler->doCompile(’{extends file=’…’) #11 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(271): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Template)) #12 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(426): Smarty_Internal_Template->compileTemplateSource() #13 Enlight/Template/Template.php(46): Smarty_Internal_Template->renderTemplate() #14 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(568): Enlight_Template_Template->renderTemplate() #15 Vendor/Smarty/libs/Smarty.class.php(328): Smarty_Internal_Template->getRenderedTemplate() #16 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(865): Smarty->fetch(Object(Enlight_Template_Template)) #17 Enlight/View/ViewDefault.php(153): Smarty_Internal_Template->fetch() #18 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(87): Enlight_View_ViewDefault->render(Object(Enlight_Template_Template)) #19 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(102): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Template)) #20 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(43): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #21 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Event_EventArgs)) #22 Enlight/Event/EventHandler.php(60): call_user_func(Array, Object(Enlight_Event_EventArgs)) #23 Enlight/Event/EventManager.php(70): Enlight_Event_EventHandler->execute(Object(Enlight_Event_EventArgs)) #24 Enlight/Controller/Action.php(76): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Array) #25 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‘indexAction’) #26 Enlight/Controller/Front.php(99): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #27 Shopware/Bootstrap.php(33): Enlight_Controller_Front->dispatch() #28 Enlight/Application.php(86): Shopware_Bootstrap->run() #29 shopware.php(6): Enlight_Application->run() #30 {main} Ich habe es per Hand versucht und auch die Download-Dateien per FTP auf den Server gespielt. Beide Male kommt diese Fehlermeldung. Ich benütze Shopware 3.5.6 . Bitte um Hilfe. Carsten Klenert
Hallo ck2geek, der Titel des Tutorials ist etwas irreführend. Es geht darum, die neue Emotions in einem 3.5er Shopware-Template, Betrieben unter Shopware4, zu nutzen. Gruß Benjamin :shopware:
Wäre ja auch zu schön gewesen. Trotzdem vielen Dank für die schnelle Antwort. Carsten Klenert
