Leider nein. Und ich finde auch keine Möglichkeit das Debug Level zu erhöhen.
Habe mich jetzt nochmal mit der Chrome-Entwicklerkonsole beschäftigt und bin auf folgende Fehlerbeschreibung gestoßen:
An exception occurred while executing 'INSERT INTO s_emotion (show_listing, template_id, parent_id, active, name, userID, position, device, fullscreen, valid_from, is_landingpage, seo_title, seo_keywords, seo_description, valid_to, create_date, modified, rows, cols, cell_spacing, cell_height, article_height, mode) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' with params [0, 1, null, 1, "Gutschein vorbestellen - Mail an kontakt@ - Copy", 52, 6, "0,1,2,3,4", 0, null, 0, "", "", "", null, "2019-01-04 15:54:48", "2019-01-04 15:54:48", 20, 12, 10, 240, 2, "rows"]: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'rows, cols, cell_spacing, cell_height, article_height, mode) VALUES (0, 1, NULL,' at line 1 in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 119
Stack trace:
#0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Statement.php(175): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), 'INSERT INTO s_e...', Array)
#1 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(281): Doctrine\DBAL\Statement->execute()
#2 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(1018): Doctrine\ORM\Persisters\Entity\BasicEntityPersister->executeInserts()
#3 vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(378): Doctrine\ORM\UnitOfWork->executeInserts(Object(Doctrine\ORM\Mapping\ClassMetadata))
#4 vendor/doctrine/orm/lib/Doctrine/ORM/EntityManager.php(356): Doctrine\ORM\UnitOfWork->commit(NULL)
#5 engine/Shopware/Controllers/Backend/Emotion.php(428): Doctrine\ORM\EntityManager->flush()
#6 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_Emotion->duplicateAction()
#7 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('duplicateAction')
#8 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch()
#10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#13 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#14 shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15 {main}
In der DBALException.php in line 119 steht:
return new self($msg, 0, $driverEx);
Hilft dir das?
