Servs,
faile gerade an den e2e Tests mit der Docker Installation (brahcn ist auf dem aktuellsten Stand):
./psh.phar e2e:init
SHOPWARE Developer Version
       _
   ___| |__  ________  _____ ___ ___
  / __| '_ \ / _ \| '_ \ \ /\ / / _` | '__ / _ \
  \__\ | | | (_) | |_) \ V V / (_| | | |__/
  | ___/_| |_|\___ /| . __/ \_/\_/ \__ ,_|_| \___|
                  |_|
Using .psh.yaml.dist
Starting Execution of 'e2e:init' ('/var/www/shopware6/development/dev-ops/e2e/actions/init.sh')
(1/1) Starting
> if [[-z ""]]; then ./psh.phar e2e:init-docker; else ./psh.phar e2e:init-local; fi
        sh: 1: [[: not found
               _
                          |_|
        Starting Execution of 'e2e:init-local' ('/var/www/shopware6/development/dev-ops/e2e/actions/init-local.sh')
        (1/1) Starting
        > npm clean-install --prefix vendor/shopware/platform/src/Administration/Resources/e2e/;
                Usage: npm
                where is one of:
                    access, adduser, audit, bin, bugs, c, cache, ci, cit,
                    completion, config, create, ddp, dedupe, deprecate,
                    dist-tag, docs, doctor, edit, explore, get, help,
                    help-search, hook, i, init, install, install-test, it, link,
                    list, ln, login, logout, ls, outdated, owner, pack, ping,
                    prefix, profile, prune, publish, rb, rebuild, repo, restart,
                    root, run, run-script, s, se, search, set, shrinkwrap, star,
                    stars, start, stop, t, team, test, token, tst, un,
                    uninstall, unpublish, unstar, up, update, v, version, view,
                    whoami
                npm -h quick help on
                npm -l display full usage info
                npm help search for help on
                npm help npm involved overview
                Specify configs in the ini-formatted file:
                    /home/micha/.npmrc
                or on the command line via: npm --key value
                Config info can be viewed via: npm help config
                npm@6.4.1 /usr/local/lib/node_modules/npm
                Did you mean one of these?
                    uninstall
                    install
        Execution aborted, a subcommand failed!
Jemand ne Idee?
       _
                  |_|
Starting Execution of 'e2e:init-docker' ('/var/www/shopware6/development/dev-ops/e2e/actions/init-docker.sh')
(1/2) Starting
> docker exec -u 1000:1000 45e63f15053952868e7bdc5e976eecd6d23247270b2f1717b1dd43e893d7824d npm clean-install --prefix app/vendor/shopware/platform/src/Administration/Resources;
        npm WARN prepare removing existing node_modules/ before installation
        added 698 packages in 4.731s
(2/2) Starting
> docker exec -u 1000:1000 45e63f15053952868e7bdc5e976eecd6d23247270b2f1717b1dd43e893d7824d npm clean-install --prefix ./e2e-Administration;
        npm ERR! path /e2e-Administration/package.json
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open '/e2e-Administration/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR! A complete log of this run can be found in:
        npm ERR! /home/node/.npm/_logs/2019-09-24T20_19_18_076Z-debug.log
Entnommen aus der Doku -> https://docs.shopware.com/en/shopware-platform-dev-en/getting-started/recent-updates#2019-06-17-cypress-as-e2e-testing-framework
