Ich bekomme am laufenden Band Emails mit diesem Inhalt Woran liegt das bzw. Was muss ich machen das es Funktioniert ? PDOException: SQLSTATE [23000]: Integrität Einschränkungsverletzung: 1048 Spalte 'Element\_ID' nicht in /www/htdocs/w014b934/shop/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:987 null sein Stack-Trace: # 0 /www/htdocs/w014b934/shop/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(987): PDOStatement-\> execute () # 1 /www/htdocs/w014b934/shop/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(100): Lehre \ DBAL \ connection-\> executeUpdate ( 'INTO s\_c INSERT ...', Array) # 2 /www/htdocs/w014b934/shop/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(61): Shopware \ Bundle \ PluginInstallerBundle \ Service \ UniqueIdGenerator \ UniqueIdGenerator-\> storeUniqueIdInDb ( 'AglXN61CxvtL6Pa ... ') # 3 /www/htdocs/w014b934/shop/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(453): Shopware \ Bundle \ PluginInstallerBundle \ Service \ UniqueIdGenerator \ UniqueIdGenerator-\> GetUniqueID () # 4 /www/htdocs/w014b934/shop/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(266): Shopware\_Controllers\_Backend\_SwagUpdate-\> getUnique () # 5 /www/htdocs/w014b934/shop/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_SwagUpdate-\> popupAction () # 6 /www/htdocs/w014b934/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\> dispatch ( 'popupAction') # 7 /www/htdocs/w014b934/shop/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\> dispatch (Object (Enlight\_Controller\_Request\_RequestHttp), Object (Enlight\_Controller\_Response\_ResponseHttp)) # 8 /www/htdocs/w014b934/shop/engine/Shopware/Kernel.php(180): Enlight\_Controller\_Front-\> dispatch () # 9 /www/htdocs/w014b934/shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware \ Kernel-\> handle (Object (Enlight\_Controller\_Request\_RequestHttp), 1, true) # 10 /www/htdocs/w014b934/shop/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony \ Component \ HttpKernel \ Httpcache \ HttpCache-\> nach vorne (Object (Symfony \ Component \ HttpFoundation \ Request), wahr, NULL) # 11 /www/htdocs/w014b934/shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware \ Components \ Httpcache \ AppCache-\> nach vorne (Object (Symfony \ Component \ HttpFoundation \ Request), wahr) # 12 /www/htdocs/w014b934/shop/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony \ Component \ HttpKernel \ Httpcache \ HttpCache-\> Pass (Object (Symfony \ Component \ HttpFoundation \ Request), wahr) # 13 /www/htdocs/w014b934/shop/shopware.php(117): Shopware \ Components \ Httpcache \ AppCache-\> handle (Object (Symfony \ Component \ HttpFoundation \ Request)) # 14 {main} Weiter Lehre \ DBAL \ DBALException: Eine Ausnahme ist aufgetreten, während 'in s\_core\_config\_values Ausführung von INSERT (Element\_ID, shop\_id, value) VALUES ( (SELECT id FROM s\_core\_config\_elements WHERE name LIKE 'trackingUniqueId' LIMIT 1), 1,? ) 'Mit params ["s: 32: \" AglXN61CxvtL6PaFVaQ0XlBl8DSaq0sQ \ ";"]: SQLSTATE [23000]: Integrität Einschränkungsverletzung: 1048 Spalte 'Element\_ID' kann in /www/htdocs/w014b934/shop/vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php:119 nicht null sein Stack-Trace: # 0 /www/htdocs/w014b934/shop/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(996): Lehre \ DBAL \ DBALException :: driverExceptionDuringQuery (Object (Lehre \ DBAL \ Driver \ PDOMySql \ Driver ), Object (PDOException), 'in s\_c INSERT ...', Array) # 1 /www/htdocs/w014b934/shop/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(100): Lehre \ DBAL \ connection-\> executeUpdate ( 'INTO s\_c INSERT ...', Array) # 2 /www/htdocs/w014b934/shop/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(61): Shopware \ Bundle \ PluginInstallerBundle \ Service \ UniqueIdGenerator \ UniqueIdGenerator-\> storeUniqueIdInDb ( 'AglXN61CxvtL6Pa ... ') # 3 /www/htdocs/w014b934/shop/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(453): Shopware \ Bundle \ PluginInstallerBundle \ Service \ UniqueIdGenerator \ UniqueIdGenerator-\> GetUniqueID () # 4 /www/htdocs/w014b934/shop/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(266): Shopware\_Controllers\_Backend\_SwagUpdate-\> getUnique () # 5 /www/htdocs/w014b934/shop/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_SwagUpdate-\> popupAction () # 6 /www/htdocs/w014b934/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\> dispatch ( 'popupAction') # 7 /www/htdocs/w014b934/shop/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\> dispatch (Object (Enlight\_Controller\_Request\_RequestHttp), Object (Enlight\_Controller\_Response\_ResponseHttp)) # 8 /www/htdocs/w014b934/shop/engine/Shopware/Kernel.php(180): Enlight\_Controller\_Front-\> dispatch () # 9 /www/htdocs/w014b934/shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware \ Kernel-\> handle (Object (Enlight\_Controller\_Request\_RequestHttp), 1, true) # 10 /www/htdocs/w014b934/shop/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony \ Component \ HttpKernel \ Httpcache \ HttpCache-\> nach vorne (Object (Symfony \ Component \ HttpFoundation \ Request), wahr, NULL) # 11 /www/htdocs/w014b934/shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware \ Components \ Httpcache \ AppCache-\> nach vorne (Object (Symfony \ Component \ HttpFoundation \ Request), wahr) # 12 /www/htdocs/w014b934/shop/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony \ Component \ HttpKernel \ Httpcache \ HttpCache-\> Pass (Object (Symfony \ Component \ HttpFoundation \ Request), wahr) # 13 /www/htdocs/w014b934/shop/shopware.php(117): Shopware \ Components \ Httpcache \ AppCache-\> handle (Object (Symfony \ Component \ HttpFoundation \ Request)) # 14 {main}
Zeit:
2017-03-17T08: 18: 59,766941 + 0100
Kanal:
Ader
anfordern:
{ "Uri": "/ backend / SwagUpdate / Popup \_DC = 1489735140693?", "Methode": "GET", "Abfrage": { "\_DC": "1489735140693", "Modul": "Backend", "Controller": "SwagUpdate", "Aktion": "Pop-up" }, "Post": [] }
Geschäft:
Kein Shop Daten verfügbar
Session:
{ "UserId": "50", "RoleID": "1" }
