Fehler LOG Datei PDOException: SQLSTATE(23000):
meine System LOG gibt mir permanent folgende Fehlermeldung aus:
PDOException: SQLSTATE(23000): Integrity constraint violation: 1048 Column ‘element_id’ cannot be null in /vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:1006 Stack trace:
#0 /vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(1006): PDOStatement->execute()
#1 /engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(98): Doctrine\DBAL\Connection->executeUpdate(‘INSERT INTO s_c…’, Array)
#2 /engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(59): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator->storeUniqueIdInDb(‘8zLE57eV9w7HyDw…’)
#3 /engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(493): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator->getUniqueId()
#4 /engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(273): Shopware_Controllers_Backend_SwagUpdate->getUnique()
#5 /engine/Library/Enlight/Controller/Action.php(192): Shopware_Controllers_Backend_SwagUpdate->popupAction()
#6 /engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight_Controller_Action->dispatch(‘popupAction’)
#7 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#8 /engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#9 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#10 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 /engine/Shopware/Components/HttpCache/AppCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /www/highticket/shopware/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15
Foreign Keys Reparatur brachte keinen Erfolg ;( Hat noch jemand ein Idee?
Vielen, vielen Dank im Voraus
