Hallo!
Ich bekomme neuerdings extrem viele Email mit Error-Meldungen, sowohl wenn Kunden sich im Shop „bewegen“ als auch wenn ich mich selbst anmelde.
Dann kommt zum Beispiel:
ERROR
Message:
exception 'PDOException' with message 'SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'element\_id' cannot be null' in /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:987 Stack trace: #0 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(987): PDOStatement-\>execute() #1 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(102): Doctrine\DBAL\Connection-\>executeUpdate('INSERT INTO s\_c...', Array) #2 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(61): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator-\>storeUniqueIdInDb('0hZwlV3OMeChWAy...') #3 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(453): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator-\>getUniqueId() #4 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(266): Shopware\_Controllers\_Backend\_SwagUpdate-\>getUnique() #5 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_SwagUpdate-\>popupAction() #6 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('popupAction') #7 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #8 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Kernel.php(180): Enlight\_Controller\_Front-\>dispatch() #9 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #10 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #11 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #12 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #13 /var/www/vhosts/zawo-tec-shop.de/httpdocs/shopware.php(117): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main} Next exception 'Doctrine\DBAL\DBALException' with message 'An exception occurred while executing 'INSERT INTO s\_core\_config\_values (element\_id, shop\_id, value) VALUES ( (SELECT id FROM s\_core\_config\_elements WHERE name LIKE 'trackingUniqueId' LIMIT 1), 1, ? )' with params ["s:32:\"0hZwlV3OMeChWAybPJqgQEhQ9wIvRHpd\";"]: SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'element\_id' cannot be null' in /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php:119 Stack trace: #0 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(996): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), 'INSERT INTO s\_c...', Array) #1 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(102): Doctrine\DBAL\Connection-\>executeUpdate('INSERT INTO s\_c...', Array) #2 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(61): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator-\>storeUniqueIdInDb('0hZwlV3OMeChWAy...') #3 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(453): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator-\>getUniqueId() #4 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Plugins/Default/Backend/SwagUpdate/Controllers/Backend/SwagUpdate.php(266): Shopware\_Controllers\_Backend\_SwagUpdate-\>getUnique() #5 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_SwagUpdate-\>popupAction() #6 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('popupAction') #7 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #8 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Kernel.php(180): Enlight\_Controller\_Front-\>dispatch() #9 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #10 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #11 /var/www/vhosts/zawo-tec-shop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #12 /var/www/vhosts/zawo-tec-shop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #13 /var/www/vhosts/zawo-tec-shop.de/httpdocs/shopware.php(117): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main}
Time:
2017-05-22T14:19:57.800955+0200
Channel:
core
request:
{ "uri": "/backend/SwagUpdate/popup?\_dc=1495455598075", "method": "GET", "query": { "\_dc": "1495455598075", "module": "backend", "controller": "SwagUpdate", "action": "popup" }, "post": [] }
shop:
No shop data available
session:
{ "userId": "52", "roleId": "1"
Hat jemand eine Ahnung?? Vielen Dank schon mal.
