Hallo an euch alle hier,
ich bin hier Neueinsteiger da vor kurzem von modified auf Shopware gewechselt. Auch der E-Mail Fehler Info Service ist super, man weiss sofort, wenn was nicht stimmt.
Ich schreibe dass, da in meinem E-Mail Postfach seit einigen Tagen immer der gleiche Fehler eingeht:
exception 'Shopware\Components\CSRFTokenValidationException' with message 'The provided X-CSRF-Token is invalid. Please go back, reload the page and try again.' in /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Shopware/Components/CSRFTokenValidator.php:161 Stack trace: #0 [internal function]: Shopware\Components\CSRFTokenValidator-\>checkFrontendTokenValidation(Object(Enlight\_Controller\_ActionEventArgs)) #1 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs)) #2 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #3 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Library/Enlight/Controller/Action.php(143): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #4 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction') #5 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #6 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Shopware/Kernel.php(178): Enlight\_Controller\_Front-\>dispatch() #7 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #8 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #9 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #10 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #11 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Shopware/Components/HttpCache/AppCache.php(133): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #12 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #13 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 /www/htdocs/w01537bc/potsdamer-schraubenhandel.com/shopware.php(113): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main}
Time:
2017-01-25T13:08:11.915602+0100
Channel:
core
request:
{ "uri": "/newsletter", "method": "POST", "query": { "module": "frontend", "controller": "newsletter", "action": "index" }, "post": { "subscribeToNewsletter": "1", "newsletter": "" } }
session:
No session data available
shopId:
1
Auch ein Austausch der Datei: CSRFTokenValidator.php:161 aus einer FTP Sicherung stellt den Fehler nicht ab.
Anruf bei Shopware brauchte kein Erfolg, da ich erstmal die Comunity Version teste gibt es ja keinen Support… Daher bitte ich euch nun hiermit mum ein kurzes Feedback bzw. Hilfe.
gruss
marth0331
