Hallo, Neuer Server, gleiche Konfiguration, woher kommen diese Fehler im Frontend?
Fatal error : Unsupported operand types in /var/www/vhosts/henri.de/httpdocs/engine/Shopware/Controllers/Frontend/Checkout.php on line 604
Überall fehler…!!! PHP Version 5.2.17-0.dotdeb.0
Bist du dir sicher, dass das PHP 5.2.17 ist und nicht etwa PHP 5.2.6. oder älter?
Jeap bin ich mir definitiv sicher
PHP Version 5.2.17-0.dotdeb.0 System Linux s15506875.onlinehome-server.info 2.6.32-bpo.5-amd64 #1 SMP Thu Oct 21 10:02:18 UTC 2010 x86\_64 Build Date Jan 7 2011 07:28:22 Server API Apache 2.0 Handler Virtual Directory Support disabled Configuration File (php.ini) Path /etc/php5/apache2 Loaded Configuration File /etc/php5/apache2/php.ini Scan this dir for additional .ini files /etc/php5/apache2/conf.d additional .ini files parsed /etc/php5/apache2/conf.d/curl.ini, /etc/php5/apache2/conf.d/gd.ini, /etc/php5/apache2/conf.d/imap.ini, /etc/php5/apache2/conf.d/ioncube-loader-5.2.ini, /etc/php5/apache2/conf.d/mysql.ini, /etc/php5/apache2/conf.d/mysqli.ini, /etc/php5/apache2/conf.d/pdo.ini, /etc/php5/apache2/conf.d/pdo\_mysql.ini, /etc/php5/apache2/conf.d/pdo\_sqlite.ini, /etc/php5/apache2/conf.d/sqlite.ini, /etc/php5/apache2/conf.d/xsl.ini PHP API 20041225 PHP Extension 20060613 Zend Extension 220060519 Debug Build no Thread Safety disabled Zend Memory Manager enabled IPv6 Support enabled Registered PHP Streams https, ftps, compress.zlib, compress.bzip2, php, file, data, http, ftp, zip Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, sslv2, tls Registered Stream Filters zlib.\*, bzip2.\*, convert.iconv.\*, string.rot13, string.toupper, string.tolower, string.strip\_tags, convert.\*, consumed This server is protected with the Suhosin Patch 0.9.7 Copyright (c) 2006 Hardened-PHP Project This program makes use of the Zend Scripting Language Engine: Zend Engine v2.2.0, Copyright (c) 1998-2010 Zend Technologies with the ionCube PHP Loader v4.0.7, Copyright (c) 2002-2011, by ionCube Ltd. This program was built by Dotdeb.
So, hab nun den Server wieder eine Version nach unte gedowngraded und nun läufts wieder… seltsam kann das jemand bestätigen?
Nö - bei mir läuft das auf Debian Lenny mit den aktuellen Dotdeb Packages -
Okay, gefunden… Es gibt wohl ein Problem mit dem Suhosin…
