Different cover product photo per language
Hi all,
is there any way to load different cover pictures of product depend on chosen language in shopware
thank You
There a plugins in the Shopwre store for that.
can i do it somehow in custom fields.only one plugin and quite exspencive
Sure. You can add the uuid of the media to a custom field and then load, depending on the languageId, a different image.
You might need do extend several template files, depending on which pictures you want to override.
sure,thank You for guide,i have cover pictures with text and icons on different languages so i need to load just them different
