ich habe heute ein Update auf 5.21 gemacht und komme leider weder in das Backend noch in das Frontend.
Es erscheint folgender Fehler:
 Slim Application Error The application could not run because of the following error: Details \*Type:\* RuntimeException \*Code:\* 1045 \*Message:\* Could not connect to database. Message from SQL Server: SQLSTATE[HY000] [1045] Access denied for user '\*\*\*\*\*\*'@'localhost' (using pass\*\*\*\*\*\*rd: YES) \*[File:\*](File:*) /var/www/virtual/wo/html/engine/Shopware/Components/DependencyInjection/Bridge/Db.php \*Line:\* 71 Trace #0 /var/www/virtual/wo/html/engine/Shopware/Kernel.php(275): Shopware\Components\DependencyInjection\Bridge\Db::createPDO(Array) #1 /var/www/virtual/wo/html/recovery/update/src/DependencyInjection/Container.php(175): Shopware\Kernel-\>boot() #2 /var/www/virtual/wo/html/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Update\DependencyInjection\Container-
Shopware\Recovery\Update\DependencyInjection{closure}(Object(Pimple\Container))
 #3 /var/www/virtual/wo/html/recovery/update/src/DependencyInjection/Container.php(184): Pimple\Container-\>offsetGet('shopware.contai...') #4 /var/www/virtual/wo/html/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Update\DependencyInjection\Container-
 #5 /var/www/virtual/wo/html/recovery/common/src/DependencyInjection/Container.php(80): Pimple\Container-\>offsetGet('shopware.theme\_...') #6 /var/www/virtual/wo/html/recovery/update/src/app.php(164): Shopware\Recovery\Common\DependencyInjection\Container-
get(‚shopware.theme_…‘)
 #7 [internal function]: {closure}() #8 /var/www/virtual/wo/html/recovery/common/vendor/slim/slim/Slim/Route.php(462): call\_user\_func\_array(Object(Closure), Array) #9 /var/www/virtual/wo/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route-\>dispatch() #10 /var/www/virtual/wo/html/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim-\>call() #11 /var/www/virtual/wo/html/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash-\>call() #12 /var/www/virtual/wo/html/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride-\>call() #13 /var/www/virtual/wo/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions-\>call() #14 /var/www/virtual/wo/html/recovery/update/index.php(46): Slim\Slim-\>run() #15 {main}
PS: die ~/config.php sieht korrekt aus
