Update auf 5.3.4 - Slim Application Error bei der Installation
im Abschluss der Installation bekomme ich folgende Fehlermeldung:
Type:  RuntimeException
Code:  2019
Message:  Could not connect to database. Message from SQL Server: SQLSTATE[HY000] [2019] Can’t initialize character set utf8mb4 (path: /usr/share/mysql/charsets/)
File:  /home/lindstae/public_html/shop/engine/Shopware/Components/DependencyInjection/Bridge/Db.php
Line:  78
Trace
#0 /home/lindstae/public_html/shop/engine/Shopware/Kernel.php(283): Shopware\Components\DependencyInjection\Bridge\Db::createPDO(Array)#1 /home/lindstae/public_html/shop/recovery/update/src/DependencyInjection/Container.php(180): Shopware\Kernel->boot()#2 /home/lindstae/public_html/shop/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection{closure}(Object(Pimple\Container))#3 /home/lindstae/public_html/shop/recovery/update/src/DependencyInjection/Container.php(189): Pimple\Container->offsetGet(‚shopware.contai…‘)#4 /home/lindstae/public_html/shop/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(113): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection{closure}(Object(Pimple\Container))#5 /home/lindstae/public_html/shop/recovery/common/src/DependencyInjection/Container.php(80): Pimple\Container->offsetGet(‚shopware.theme_…‘)#6 /home/lindstae/public_html/shop/recovery/update/src/app.php(169): Shopware\Recovery\Common\DependencyInjection\Container->get(‚shopware.theme_…‘)#7 [internal function]: {closure}()#8 /home/lindstae/public_html/shop/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)#9 /home/lindstae/public_html/shop/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()#10 /home/lindstae/public_html/shop/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()#11 /home/lindstae/public_html/shop/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()#12 /home/lindstae/public_html/shop/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()#13 /home/lindstae/public_html/shop/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()#14 /home/lindstae/public_html/shop/recovery/update/index.php(69): Slim\Slim->run()
#15 {main}
der Shop und das Backend laufen nur noch im Wartungsmodus.
Was muss ich machen?
Schöne Grüße Tjerk
Das ist ein Fehler von Mysql, Shopware ist hier wohl unschuldig: MySQL :: MySQL 5.7 Reference Manual :: B.3.2.15 Can't initialize character set
Kannst du dich mit dem mysql Client mit der DB verbinden?
Was ist das für ein System? Wie wurde MySQL installiert?
Thomas
Ja, ich kann mich mit phpMyAdmin mit der DB verbinden.
Ich habe den Provider dazu mal kontaktiert.
Danke für die Hilfe.
Oder ist dies ein Fehler im Datenbank Import? In der Strucktur der Tabellen kann ich utf8mb4 auswählen.
wir hatten das gleiche Problem, es lag an der eingesetzten PHP-Version. Nachdem Update auf 5.6.32 funktioniert alles einwandfrei.
VG,
Achim
