create link in product desccription
in the product description I would like to create a link to another product. Should I do this with insert link and with the product url? Or is there a better way? For exaple if the url changes I have a broken link…
If you take look at the productdetails there is a tab called „Crossselling“.
There you can define which products shall be combined.
Thx! And if I want to create a link to a page on our website, should I use insert link I guess?
