ich habe ein Problem bei dem ich nicht mehr weiterkomme.
ich würde mich sehr freuen wenn Ihr mir Helfen könnt, bin mit meinem Latein am ende.
Die Fehlermeldung sieht wie folgt aus:
Slim Application Error
Type: RuntimeException
Message: Identifier DB not initialized yet
File: /home/gvkofjjx/htdocs/shopware/recovery/install/src/ContainerProvider.php
Line: 160
Trace
#0 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(112): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#1 /home/gvkofjjx/htdocs/shopware/recovery/install/src/ContainerProvider.php(143): Pimple\Container->offsetGet(‘db’)
#2 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(112): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#3 /home/gvkofjjx/htdocs/shopware/recovery/install/src/app.php(437): Pimple\Container->offsetGet(‘theme.service’)
#4 [internal function]: {closure}()
#5 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)
#6 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()
#7 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#8 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#9 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#10 /home/gvkofjjx/htdocs/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#11 /home/gvkofjjx/htdocs/shopware/recovery/install/index.php(74): Slim\Slim->run()
#12 {main}
beim hochladen der Datei über den FileZilla bekomme ichj gesagt diese Datei wäre nicht zu öffnen…
Was mache ich Falsch?
Danke im Vorraus
Melanie
