Hallo, wir haben das obige Plugin installiert und erhalten folgenden Fehler: Method “Shopware_Proxies_ShopwareControllersFrontendSearchProxy::getBreadcrumb” not found failure in Enlight/Event/Handler/Plugin.php on line 149 Stack trace: #0 Enlight/Controller/Action.php(395): Enlight_Class->__call(‘getBreadcrumb’, Array) #1 Shopware/Plugins/Community/Frontend/SwfLandingPages/Bootstrap.php(542): Enlight_Controller_Action->__call(‘getBreadcrumb’, Array) #2 Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Frontend_SwfLandingPages_Bootstrap->onListing(Object(Enlight_Controller_ActionEventArgs)) #3 Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs)) #4 Enlight/Controller/Action.php(202): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_ActionEventArgs)) #5 Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘defaultSearchAc…’) #6 Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #7 Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #8 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #9 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #10 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #11 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #12 Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #13 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #14 Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #15 shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #16 {main} Das Template spring zurück ins Emotion. Nicht kompatibel mit dem Responsive aus dem eigenen Hause? > Deaktivieren erzeugt den gleichen Fehler.
Haben Sie hierzu bereits einmal versucht den Support von Conexco zu kontaktieren? Die reagieren eigentlich immer schnell…
Ja, wir warten auf Feedback.
