Cart empty when user logged in..
Hi, In my shop site, When the user some items in the cart, Then they enter the login page… Guest checkout and new user checkout working fine… But, when existing user login using their credentials the shopping cart become empty… Please help me to fix this issue… it is urgent… Thanking in advance, Team
Hi, when an existing user logs in, the SessionID is regenerated, in order to prevent session hijacking. Shopware will make sure, that the cart (which is stored in the DB using the sessionID) will be updated to the new sessionID - so that this exact scenario does not happen. Your case, however, sound a bit, as if this might be related. Perhaps some plugins? You can check my thesis this way: * as a not logged in user, put something in your cart. * check the sessionID from the session cookie * it should match the latest entry in s_order_basket * now log in * check the sessionID from the session cookie * probably the latest entry in s_order_basket still have the previous value * it should have the new sessionID Please notice, that such effects can also occur, when subshop / language shop changes are involved. Best regards, Daniel
Hallo sir, As you said, when i switch my language from german to english the cart goes to empty. Please tell me a solution Thanking in advance Team
