Cache-Einstellungen speichern
Hi, beim Speichern der Cache-Einstellungen kommt immer die Meldung: [2016-01-12 15:05:42] core.ERROR: exception 'Doctrine\DBAL\Types\ConversionException' with message 'Could not convert database value "s:334:"frontend/list..." to Doctrine Type object' in /shopware/vendor/doctrine/dbal/lib/Doctrine/DBAL/Types/ConversionException.php:46 Stack trace: #0 /shopware/vendor/doctrine/dbal/lib/Doctrine/DBAL/Types/ObjectType.php(59): Doctrine\DBAL\Types\ConversionException::conversionFailed('s:334:"frontend...', 'object') #1 /shopware/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/SimpleObjectHydrator.php(128): Doctrine\DBAL\Types\ObjectType-\>convertToPHPValue('s:334:"frontend...', Object(Doctrine\DBAL\Platforms\MySqlPlatform)) #2 /shopware/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/SimpleObjectHydrator.php(69): Doctrine\ORM\Internal\Hydration\SimpleObjectHydrator-\>hydrateRowData(Array, Array) #3 /shopware/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(147): Doctrine\ORM\Internal\Hydration\SimpleObjectHydrator-\>hydrateAllData() #4 /shopware/engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(750): Doctrine\ORM\Internal\Hydration\AbstractHydrator-\>hydrateAll(Object(PDOStatement), Object(Doctrine\ORM\Query\ResultSetMapping), Array) #5 /shopware/vendor/doctrine/orm/lib/Doctrine/ORM/EntityRepository.php(196): Doctrine\ORM\Persisters\Entity\BasicEntityPersister-\>load(Array, NULL, NULL, Array, NULL, 1, NULL) #6 /shopware/engine/Shopware/Controllers/Backend/Performance.php(398): Doctrine\ORM\EntityRepository-\>findOneBy(Array) #7 /shopware/engine/Shopware/Controllers/Backend/Performance.php(226): Shopware\_Controllers\_Backend\_Performance-\>saveConfig('cacheController...', '') #8 /shopware/engine/Shopware/Controllers/Backend/Performance.php(204): Shopware\_Controllers\_Backend\_Performance-\>saveConfigData(Array) #9 /shopware/engine/Library/Enlight/Controller/Action.php(158): Shopware\_Controllers\_Backend\_Performance-\>saveConfigAction() #10 /shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('saveConfigActio...') #11 /shopware/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #12 /shopware/engine/Shopware/Kernel.php(148): Enlight\_Controller\_Front-\>dispatch() #13 /shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 /shopware/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #15 /shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #16 /shopware/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #17 /shopware/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #18 {main} [] {"uid":"2de8b1f"} Scheint ja mit dem Element cacheControllers in der s_core_config_elements zusammenzuhängen? Wenn man den Wert in Value löscht und dann Shopware neu lädt und die Einstellungen speichert steht hier wieder s:334:"frontend/listing 3600frontend/index 3600frontend/detail 3600frontend/campaign 14400widgets/listing 14400frontend/custom 14400frontend/sitemap 14400frontend/blog 14400widgets/index 3600widgets/checkout 3600widgets/compare 3600widgets/emotion 14400widgets/recommendation 14400widgets/lastArticles 3600widgets/campaign 3600"; drin. Der gleiche Wert steht aber auch in anderen Shops und da geht es problemlos. Hat das Problem schon einmal jemand gehabt oder kennt eine Lösung? Danke schon mal.
Hallo, sieht mir danach aus, als fehlt ein Config-Element in der Datenbank. Wenn du SW5 hast, könntest du mal das HTTP-Cache Plugin neu installieren, vielleicht hilft das schon. Du kannst dafür die getCapabilities auf true setzen, dann erscheint das Plugin wieder im Plugin-Manager und du kannst einen Reinstall ausführen: https://github.com/shopware/shopware/bl … p.php#L151 Dann sollten auch die Elemente wieder angelegt werden. Vielleicht hilft das ja schon. Moritz
Super danke, hat geklappt
Ich hatte dasselbe Problem - bei mir hat eine Neu-Installation des Cache-Plugins nichts gebracht.
Ursache in meinem Fall war ein fehlerhafter JSON-String, der ans Backend gesendet wurde. Der enthaltene Fehler wurde dadurch verursacht, dass bei der vorhandenen Shop-Installation noch kein Such-Index aufgebaut war. Nachdem ich diesen aufgebaut habe, klappt es nun auch mit dem Speichern.
