Hallo Zusammen,
heute Morgen habe ich die Seite aufgemacht, leider sind da nur die unten angegebenen Fehlermeldungen. Das Komische daran ich hab nichts verändert.
Bitte um dringend Hilfe.
Danke im Voraus
Warning : include(/var/www/web24684345/html/saasil.de/vendor/composer/…/…/engine/Shopware/Components/DependencyInjection/ContainerAwareInterface.php): failed to open stream: No such file or directory in /var/www/web24684345/html/saasil.de/vendor/composer/ClassLoader.php on line 444
Warning : include(): Failed opening ‚/var/www/web24684345/html/saasil.de/vendor/composer/…/…/engine/Shopware/Components/DependencyInjection/ContainerAwareInterface.php‘ for inclusion (include_path=’/var/www/web24684345/html/saasil.de/engine/Library:.:/opt/php/7.2.21/share/pear’) in /var/www/web24684345/html/saasil.de/vendor/composer/ClassLoader.php on line 444
Fatal error : Uncaught ReflectionException: Class Shopware\Components\DependencyInjection\ContainerAwareInterface not found in /var/www/web24684345/html/saasil.de/engine/Shopware/Commands/ShopwareCommand.php:39 Stack trace: #0 /var/www/web24684345/html/saasil.de/vendor/composer/ClassLoader.php(444): include(’/var/www/web246…’) #1 /var/www/web24684345/html/saasil.de/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile(’/var/www/web246…’) #2 [internal function]: Composer\Autoload\ClassLoader->loadClass(‚Shopware\Comman…‘) #3 /var/www/web24684345/html/saasil.de/custom/plugins/FgitsAutoInvoice/Commands/ProcessOrdersCommand.php(15): spl_autoload_call(‚Shopware\Comman…‘) #4 /var/www/web24684345/html/saasil.de/vendor/symfony/class-loader/Psr4ClassLoader.php(69): require(’/var/www/web246…’) #5 [internal function]: Symfony\Component\ClassLoader\Psr4ClassLoader->loadClass(‚FgitsAutoInvoic…‘) #6 [internal function]: spl_autoload_call(‚FgitsAutoInvoic…‘) #7 /var/www/web24684345/html/saasil.de/vendor/symf in /var/www/web24684345/html/saasil.de/engine/Shopware/Commands/ShopwareCommand.php on line 39
