Ich habe das Problem das wenn ich die Bestellungen aufrufen will immer folgende Fehlermeldung erscheint, wer kann bei der Lösung helfen? Shopware-Version 5.1.6
unable to write file /var/www/web35/html/var/cache/production_201605230943/templates/backend_de_DE_a98d9/d0/1b/63/wrt59a1378b093732.75865396 in Smarty/sysplugins/smarty_internal_write_file.php on line 48
Stack trace:
#0 Smarty/sysplugins/smarty\_internal\_template.php(201): Smarty\_Internal\_Write\_File::writeFile('/var/www/web35/...', '\<?php /\* Smarty...', Object(Enlight\_Template\_Manager))
#1 Smarty/sysplugins/smarty\_internal\_templatebase.php(155): Smarty\_Internal\_Template-\>compileTemplateSource()
#2 Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(NULL, NULL, NULL, NULL, false, false, true)
#3 var/cache/production\_201605230943/templates/backend\_de\_DE\_a98d9/70/88/85/708885a174b217ba75dbc208d987066f8dc53f40.snippet.3c541067a27cb6d137c46d8ae0a40d5271765aed.php(36): Smarty\_Internal\_Template-\>getSubTemplate('/var/www/web35/...', NULL, 'backend\_de\_DE\_a...', NULL, NULL, Array, 0)
#4 Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_59a1378af10418\_49907558(Object(Enlight\_Template\_Default))
#5 Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch()
#6 Shopware/Plugins/Community/Backend/ViisonDHL/ViisonCommon/Components/ViisonCommonJSLoader.php(188): Enlight\_View\_Default-\>render()
#7 Shopware/Plugins/Community/Backend/ViisonDHL/ViisonCommon/Components/ViisonCommonJSLoader.php(160): Shopware\Plugins\ViisonCommon\Components\ViisonCommonJSLoader-\>renderSubApp()
#8 Shopware/Plugins/Community/Backend/ViisonDHL/ViisonCommon/Components/ViisonCommonJSLoader.php(139): Shopware\Plugins\ViisonCommon\Components\ViisonCommonJSLoader-\>renderSubApps()
#9 Shopware/Plugins/Community/Backend/ViisonDHL/ViisonCommon/Subscriber/Common.php(221): Shopware\Plugins\ViisonCommon\Components\ViisonCommonJSLoader-\>loadShopwareSubAppExtensions()
#10 [internal function]: Shopware\Plugins\ViisonCommon\Subscriber\Common-\>onViewRendererFilterRender(Object(Enlight\_Event\_EventArgs))
#11 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Event\_EventArgs))
#12 Enlight/Event/EventManager.php(303): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Event\_EventArgs))
#13 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(221): Enlight\_Event\_EventManager-\>filter('Enlight\_Plugins...', '/\*\*\n \* Shopware...', Array)
#14 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
#15 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
#16 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
#17 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
#18 Enlight/Event/EventManager.php(213): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
#19 Enlight/Controller/Action.php(201): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
#20 Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction')
#21 Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
#22 Shopware/Kernel.php(153): Enlight\_Controller\_Front-\>dispatch()
#23 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#24 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#25 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
#26 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
#27 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
#28 {main}
