Bestellung geht nicht raus - Fehlermeldung Ups! etc...
Wenn ich eine Bestellung abschicke, Zahlung per Vorkasse oder Paypal, dann tritt immer folgender Fehler auf. Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Syntax Error in template “string:” on line 48 " {if additional.payment.name == \"debit\"} " - Unexpected "\", expected one of: "{" , "" , “identifier” , LDELIF , LDELFOR , LDELFOREACH , “closing tag” , INTEGER , “+” , “-” , “(” , “(!,not)” , TYPECAST , HEX , “.” , SINGLEQUOTESTRING , “#” , “[” , “”" in Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php on line 404 Stack trace: #0 Vendor/Smarty/libs/sysplugins/smarty_internal_templateparser.php(2699): Smarty_Internal_TemplateCompilerBase->trigger_template_error() #1 Vendor/Smarty/libs/sysplugins/smarty_internal_templateparser.php(2764): Smarty_Internal_Templateparser->yy_syntax_error(10, ‘’) #2 Vendor/Smarty/libs/sysplugins/smarty_internal_smartytemplatecompiler.php(51): Smarty_Internal_Templateparser->doParse(10, ‘’) #3 Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php(83): Smarty_Internal_SmartyTemplateCompiler->doCompile(’
compileTemplate(Object(Enlight_Template_Template)) #5 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(426): Smarty_Internal_Template->compileTemplateSource() #6 Enlight/Template/Template.php(46): Smarty_Internal_Template->renderTemplate() #7 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(568): Enlight_Template_Template->renderTemplate() #8 Vendor/Smarty/libs/Smarty.class.php(328): Smarty_Internal_Template->getRenderedTemplate() #9 engine/core/class/sOrder.php(915): Smarty->fetch('string:
sendMail(Array) #11 Shopware/Controllers/Frontend/Checkout.php(401): sOrder->sSaveOrder() #12 Shopware/Controllers/Frontend/Checkout.php(127): Shopware_Controllers_Frontend_Checkout->saveOrder() #13 Enlight/Controller/Action.php(55): Shopware_Controllers_Frontend_Checkout->finishAction() #14 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‘finishAction’) #15 Enlight/Controller/Front.php(88): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #16 Shopware/Bootstrap.php(21): Enlight_Controller_Front->dispatch() #17 Enlight/Application.php(69): Shopware_Bootstrap->run() #18 shopware.php(6): Enlight_Application->run() #19 {main}
Hi, Du hast einen Fehler in Deiner eMail Vorlage, dazu gibt es hier schon diverse Threads… Hier die Lösung: Link Forum Thread Stefan
