Bekomme seit 1 Tag Fehlermeldung
Hallo. Bekomme seit gestern Fehlermeldungen, mit denen ich leider nichts anfangen kann. vielleicht ist ja hier jemand, der mir helfen kann.
exception 'Shopware\Components\Api\Exception\NotFoundException' with message 'Article by id 5 not found' in /var/www/web168/html/engine/Shopware/Components/Api/Resource/Article.php:155
Stack trace:
#0 /var/www/web168/html/engine/Shopware/Controllers/Api/Articles.php(76): Shopware\Components\Api\Resource\Article->getOne('5', Array)
#1 /var/www/web168/html/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Api_Articles->getAction()
#2 /var/www/web168/html/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('getAction')
#3 /var/www/web168/html/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#4 /var/www/web168/html/engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch()
#5 /var/www/web168/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#6 /var/www/web168/html/engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#7 /var/www/web168/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#8 /var/www/web168/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /var/www/web168/html/engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /var/www/web168/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /var/www/web168/html/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 /var/www/web168/html/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#13 {main}
Time:
2018-01-30T11:54:54.376322+0100
Channel:
core
request:
    "uri": "/api/articles/5",
    "method": "GET",
    "query": {
        "module": "api",
        "controller": "articles",
        "action": "5"
    "post": []
shop:
No shop data available
session:
No session data available
Kann mich nicht erinnern, das ich irgendwas gross geändert habe, also Artikel oder Plugins. Der Shop läuft zwar normal, aber das nervt doch…
Danke schonmal.
Gruss Reiner
Hast du eine Warenwirtschaft oder ähnliches angebunden? Es wird versucht einen Artikel über die API abzurufen, den es nicht gibt.
Wenn ja, kontaktiere doch mal den Hersteller.
Ich habe Billbee dran, ja, und habe dort heute mit den Artikeln gearbeitet. Da schau ich mal nach. Danke
