Hallo, Wir haben seit neusten diesen Fehler hier im Backend: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Method "Shopware\_Proxies\_ShopwareControllersBackendIndexProxy::getOpenOrdersAction" not found failure in Enlight/Controller/Action.php on line 70 Stack trace: #0 Enlight/Controller/Action.php(220): Enlight\_Class-\>\_\_call('getOpenOrdersAc...', Array) #1 Enlight/Controller/Action.php(70): Enlight\_Controller\_Action-\>\_\_call('getOpenOrdersAc...', Array) #2 Enlight/Controller/Action.php(70): Shopware\_Proxies\_ShopwareControllersBackendIndexProxy-\>getOpenOrdersAction() #3 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight\_Controller\_Action-\>dispatch('getOpenOrdersAc...') #4 Enlight/Controller/Front.php(99): Enlight\_Controller\_Dispatcher\_DispatcherDefault-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #5 Shopware/Bootstrap.php(33): Enlight\_Controller\_Front-\>dispatch() #6 Enlight/Application.php(86): Shopware\_Bootstrap-\>run() #7 shopware.php(6): Enlight\_Application-\>run() #8 {main} PHP: PHP Version 5.3.6-13ubuntu3.2 System Linux www 3.0.0-12-server #20-Ubuntu SMP Fri Oct 7 16:36:30 UTC 2011 x86\_64 Build Date Oct 13 2011 22:58:15 Server API Apache 2.0 Handler Virtual Directory Support disabled Configuration File (php.ini) Path /etc/php5/apache2 Loaded Configuration File /etc/php5/apache2/php.ini Scan this dir for additional .ini files /etc/php5/apache2/conf.d Additional .ini files parsed /etc/php5/apache2/conf.d/curl.ini, /etc/php5/apache2/conf.d/gd.ini, /etc/php5/apache2/conf.d/imagick.ini, /etc/php5/apache2/conf.d/mysql.ini, /etc/php5/apache2/conf.d/mysqli.ini, /etc/php5/apache2/conf.d/pdo.ini, /etc/php5/apache2/conf.d/pdo\_mysql.ini PHP API 20090626 PHP Extension 20090626 Zend Extension 220090626 Zend Extension Build API220090626,NTS PHP Extension Build API20090626,NTS Debug Build no Thread Safety disabled Zend Memory Manager enabled Zend Multibyte Support disabled IPv6 Support enabled Registered PHP Streams https, ftps, compress.zlib, compress.bzip2, php, file, glob, data, http, ftp, phar, zip Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, sslv2, tls Registered Stream Filters zlib.\*, bzip2.\*, convert.iconv.\*, string.rot13, string.toupper, string.tolower, string.strip\_tags, convert.\*, consumed, dechunk Suhosin logo This server is protected with the Suhosin Patch 0.9.10 Copyright (c) 2006-2007 Hardened-PHP Project Copyright (c) 2007-2009 SektionEins GmbH Zend logo This program makes use of the Zend Scripting Language Engine: Zend Engine v2.3.0, Copyright (c) 1998-2011 Zend Technologies with the ionCube PHP Loader v4.0.10, Copyright (c) 2002-2011, by ionCube Ltd. Die bemängelte Datei ist jedoch vorhanden und hat auch lese/schreib rechte, wenn ich diese File lösche, wird sie automatisch wieder angelegt im Proxies Ordner? Wäre relativ dringend… Mg Daniel
