Hallo Community,
habe die topbar-natigation.tpl umgebaut, so dass der Merkzettel, Mein Account und der Warenkorb dort angezeigt werden. Das klappt auch alles. Jedoch verschwindet dann die Sprachauswahl.
Anbei mein Code:
{* Top bar main *}
{block name="frontend_index_top_bar_main"}
{* Top bar main container *}
{block name="frontend_index_top_bar_main_container"}
{* Top bar navigation *}
{block name="frontend_index_top_bar_nav"}
{* Notepad entry *}
{block name="frontend_index_checkout_actions_notepad"}
{/block}
{* My account entry *}
{block name="frontend_index_checkout_actions_my_options"}
{/block}
{* Cart entry *}
{block name="frontend_index_checkout_actions_cart"}
{/block}
{block name="frontend_index_checkout_s_inner"}{/block}
{/block}
{action module=widgets controller=index action=shopMenu}
{* Article Compare *}
{block name='frontend_index_navigation_inline'}
{if {config name="compareShow"}}
{block name='frontend_index_navigation_compare'}
{action module=widgets controller=compare}
{/block}
{/if}
{/block}
{* Service / Support drop down *}
{block name="frontend_index_checkout_actions_service_menu"}
{s namespace='frontend/index/checkout_actions' name='IndexLinkService'}{/s}
{* Include of the widget *}
{block name="frontend_index_checkout_actions_service_menu_include"}
{include file="widgets/index/menu.tpl" sGroup=left}
{/block}
{/block}
{/block}
{/block}
{/block}
Kann mir da jemand weiterhelfen? Vielen Dank!
