5.6.0 RC1 nach Aufraeumen Error
Moin,
direkt nach dem Updaten auf  5.6.0 RC1 kommt der Aufraeum Prozess und dann folgender error:
Slim Application Error
Type:  ErrorException
Code:  2
Message:  PDO::query(): MySQL server has gone away
File:  /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/update/src/Controller/CleanupController.php
Line:  217
Trace
#0 [internal function]: Slim\Slim::handleErrors(2, ‚PDO::query(): M…‘, ‚/home/Westcoast…‘, 217, Array)
#1 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/update/src/Controller/CleanupController.php(217): PDO->query(‚SELECT shops.id…‘)
#2 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/update/src/Controller/CleanupController.php(126): Shopware\Recovery\Update\Controller\CleanupController->cleanupTemplateRelations()
#3 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/update/src/app.php(158): Shopware\Recovery\Update\Controller\CleanupController->cleanupOldFiles()
#4 [internal function]: {closure}()
#5 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#6 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#7 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#8 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#9 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#10 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#11 /home/WestcoastDK/web/westcoast-computer.dk/public_html/recovery/update/index.php(57): Slim\Slim->run()
#12 {main}
Klingt mir so, als ob das Cache löschen deinen Server überlastet hat. Reicht eigentlich aus die Update-Dateien zu löschen /files/update und dann ist das Update auch durchgelaufen.
Er schein wohl ne Abfrage zu machen auf s_core_templates und die Tabelle gibt es nicht und gab es vorher auch nicht…
Die sollte es auch bei dir geben - wenn nicht hast du ganz andere Probleme, da diese zu einer Standardinstallation von Shopware gehört seit 3.5 (etwa).
Mh im Backup ist die Tabelle jedenfalls nicht, und der Shop lief bis Dato :smiley: und im clear_cache.sh fehlte ein php vor dem Pfad in Zeile 18 :frowning:
Ich revidiere das mit der DB die Tabelle ist und war da… Nur ergibt der String SELECT id FROM s_core_templates WHERE version = 3 AND parent_id IS NOT NULL ORDER BY id ASC LIMIT 1 keine Rueckgabe  Sollte aber mindestens ein Ergebnis auswerfen da mein Template dem SQL String entspricht…
btw. ist doch kein shopware6 topic hier? :stuck_out_tongue:
hänge mich hier mal ran, ist jedoch eine andere Fehlermeldung …
Fatal error: During class fetch: Uncaught ReflectionException: Class Smarty_Internal_Resource_Extends not found in /var/www/vhosts/httpdocs/Domain/_TESTSERVER_/engine/Library/Enlight/Components/Snippet/Resource.php:32 Stack trace: #0 /var/www/vhosts/httpdocs/Domain/_TESTSERVER_/recovery/common/vendor/composer/ClassLoader.php(444): include('/var/www/vhosts...') #1 /var/www/vhosts/httpdocs/Domain/_TESTSERVER_/recovery/common/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/var/www/vhosts...') #2 [internal function]: Composer\Autoload\ClassLoader->loadClass('Enlight_Compone...') #3 [internal function]: spl_autoload_call('Enlight_Compone...') #4 /var/www/vhosts/httpdocs/Domain/_TESTSERVER_/vendor/symfony/config/Resource/ClassExistenceResource.php(78): class_exists('Enlight_Compone...') #5 /var/www/vhosts/httpdocs/Domain/_TESTSERVER_/vendor/symfony/dependency-injection/Cont in /var/www/vhosts/httpdocs/Domain/_TESTSERVER_/engine/Library/Enlight/Components/Snippet/Resource.php on line 32
@Hans_en schrieb:
Fatal error: During class fetch: Uncaught ReflectionException: Class Smarty_Internal_Resource_Extends not found in /var/www/vhosts/httpdocs/Domain/TESTSERVER/engine/Library/Enlight/Components/Snippet/Resource.php:32 Stack trace: #0 /var/www/vhosts/httpdocs/Domain/TESTSERVER/recovery/common/vendor/composer/ClassLoader.php(444): include(‚/var/www/vhosts…‘) #1 /var/www/vhosts/httpdocs/Domain/TESTSERVER/recovery/common/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile(‚/var/www/vhosts…‘) #2 [internal function]: Composer\Autoload\ClassLoader->loadClass(‚Enlight_Compone…‘) #3 [internal function]: spl_autoload_call(‚Enlight_Compone…‘) #4 /var/www/vhosts/httpdocs/Domain/TESTSERVER/vendor/symfony/config/Resource/ClassExistenceResource.php(78): class_exists(‚Enlight_Compone…‘) #5 /var/www/vhosts/httpdocs/Domain/TESTSERVER/vendor/symfony/dependency-injection/Cont in /var/www/vhosts/httpdocs/Domain/TESTSERVER/engine/Library/Enlight/Components/Snippet/Resource.php on line 32
hier gleiche Fehlermeldung:
Ubuntu 18.04 unter windows,
LAMP Stack  PHP 7.2.20. Mysql 5.7.26
Sowohl beim Installer als auch bei Update von 5.5.10 auf 5.6
Am besten ein neues Thema dazu aufmachen. Das hat mit dem Thread. Nichts zu tun. Am besten auch konkret schreiben wo, also in welchem Schritt des installer/updaters das passiert und ob das Update manuell oder per Auto updater passiert. Interessant ist auch ob der Installer auf dem Server direkt enrpackt wird oder lokal und dann hochgeladen.
Auf Basis der Fehlermeldung würde ich erstmal sagen, dass nicht alle Dateien hochgeladen wurden. Das wäre typisch für Filezilla.
ich konnte beides Lokal ohne Probleme durchführen.
