Bilder werden nicht migriert
Das hier spuckt mir die Console aus nachdem ich die Fehler ausgeben lasse.
load/?f=m/User|m/Use…1711023450+1+1:1442 Uncaught TypeError: Cannot read properties of null (reading '0')
    at i.callback (load/?f=m/User|m/Use…1023450+1+1:1442:16)
    at Object.callback (ext-all.js?202306271137:21:67496)
    at i.onProxyLoad (ext-all.js?202306271137:21:560280)
    at i.processResponse (base?file=bootstrap&…=1711023450:3405:10)
    at i.<anonymous> (ext-all.js?202306271137:21:553141)
    at i.onComplete (ext-all.js?202306271137:21:422880)
    at i.onStateChange (ext-all.js?202306271137:21:422314)
    at XMLHttpRequest.<anonymous> (ext-all.js?202306271137:21:17406)
callback	@	load/?f=m/User|m/Use…1711023450+1+1:1442
callback	@	ext-all.js?202306271137:21
onProxyLoad	@	ext-all.js?202306271137:21
processResponse	@	base?file=bootstrap&…dIn=1711023450:3405
(anonymous)	@	ext-all.js?202306271137:21
onComplete	@	ext-all.js?202306271137:21
onStateChange	@	ext-all.js?202306271137:21
XMLHttpRequest.send (async)
xhrSendProcessor	@	main.js?attr=OlI9x2L…3B2hO9lf-r3R6A:3735
send	@	main.js?attr=OlI9x2L…3B2hO9lf-r3R6A:3751
t.send	@	frame_ant.js:1
request	@	ext-all.js?202306271137:21
request	@	base?file=bootstrap&…dIn=1711023450:4779
doRequest	@	ext-all.js?202306271137:21
read	@	ext-all.js?202306271137:21
load	@	ext-all.js?202306271137:21
callParent	@	ext-all.js?202306271137:21
onEditUser	@	load/?f=m/User|m/Use…1711023450+1+1:1438
fire	@	ext-all.js?202306271137:21
dispatch	@	base?file=bootstrap&…dIn=1711023450:3863
fireEvent	@	ext-all.js?202306271137:21
handler	@	load/?f=m/User|m/Use…=1711023450+1+1:275
processEvent	@	ext-all.js?202306271137:21
continueFireEvent	@	ext-all.js?202306271137:21
processItemEvent	@	ext-all.js?202306271137:21
processUIEvent	@	ext-all.js?202306271137:21
handleEvent	@	ext-all.js?202306271137:21
eval	@	VM820:6
g	@	ext-all.js?202306271137:21
Und welcher Fehler kommt, wenn du dir die Rückgabe aus dem Netzwerktab von getUserDetails anschaust?
Diese fehler werden mir angezeigt, ich hoffe das sind die richtigen :see_no_evil:
main.js?attr=oWLW-ksx5h2-Mx59QdzNh2pizgPWEXtUoUoFZkPekjP2_IP-I4EionJ1yTT-xI9GaCYp8nMrFpiXMM1X70GYKg:3735
       GET https://ds-sportwagen-store.de/backend/UserManager/getUserDetails?_dc=1711024569973&page=1&start=0&limit=30&id=54 503 (Service Unavailable)
xhrSendProcessor @ main.js?attr=oWLW-ksx5h2-Mx59QdzNh2pizgPWEXtUoUoFZkPekjP2_IP-I4EionJ1yTT-xI9GaCYp8nMrFpiXMM1X70GYKg:3735
send @ main.js?attr=oWLW-ksx5h2-Mx59QdzNh2pizgPWEXtUoUoFZkPekjP2_IP-I4EionJ1yTT-xI9GaCYp8nMrFpiXMM1X70GYKg:3751
request @ base?file=bootstrap&loggedIn=1711024559:4779
onEditUser @ load/?f=m/User|m/UserDetail|m/Roles|m/Detail|m/Privilege|m/Resource|m/Locale|m/Rules|v/main/Window|v/user/List|v/user/Create|v/roles/List|v/rules/Tree|v/rules/Add|store/User|store/UserDetail|store/Detail|store/Roles|store/Locale|store/Rules|c/User|c/Main|c/Roles|c/Rules&no-cache=1711023450+1+1:1438
dispatch @ base?file=bootstrap&loggedIn=1711024559:3863
handler @ load/?f=m/User|m/UserDetail|m/Roles|m/Detail|m/Privilege|m/Resource|m/Locale|m/Rules|v/main/Window|v/user/List|v/user/Create|v/roles/List|v/rules/Tree|v/rules/Add|store/User|store/UserDetail|store/Detail|store/Roles|store/Locale|store/Rules|c/User|c/Main|c/Roles|c/Rules&no-cache=1711023450+1+1:275
eval @ VM1206:6
load/?f=m/User|m/UserDetail|m/Roles|m/Detail|m/Privilege|m/Resource|m/Locale|m/Rules|v/main/Window|v/user/List|v/user/Create|v/roles/List|v/rules/Tree|v/rules/Add|store/User|store/UserDetail|store/Detail|store/Roles|store/Locale|store/Rules|c/User|c/Main|c/Roles|c/Rules&no-cache=1711023450+1+1:1442 Uncaught TypeError: Cannot read properties of null (reading '0')
    at i.callback (load/?f=m/User|m/UserDetail|m/Roles|m/Detail|m/Privilege|m/Resource|m/Locale|m/Rules|v/main/Window|v/user/List|v/user/Create|v/roles/List|v/rules/Tree|v/rules/Add|store/User|store/UserDetail|store/Detail|store/Roles|store/Locale|store/Rules|c/User|c/Main|c/Roles|c/Rules&no-cache=1711023450+1+1:1442:16)
    at i.processResponse (base?file=bootstrap&loggedIn=1711024559:3405:10)
callback @ load/?f=m/User|m/UserDetail|m/Roles|m/Detail|m/Privilege|m/Resource|m/Locale|m/Rules|v/main/Window|v/user/List|v/user/Create|v/roles/List|v/rules/Tree|v/rules/Add|store/User|store/UserDetail|store/Detail|store/Roles|store/Locale|store/Rules|c/User|c/Main|c/Roles|c/Rules&no-cache=1711023450+1+1:1442
processResponse @ base?file=bootstrap&loggedIn=1711024559:3405
(anonym) @ ext-all.js?202306271137:21
eval @ VM1206:6
eval @ VM1206:6
eval @ VM1206:6
Sieht eher aus wie die Fehlermeldungen im Console-Tab.
503 ist ein Server Fehler. Also nach den Logs auf dem Server schauen ob dort ggf. noch Infos stehen.
[Thu Mar 21 12:16:42.318057 2024] [autoindex:error] [pid 69352] [client 5.83.191.55:0] AH01276: Cannot serve directory /var/www/vhosts/ds-sportwagen-store.de/httpdocs/custom/plugins/SnapsSnapstrgOneProfessional/Resources/Themes/Frontend/SnapstrgOneProfessional/frontend/_public/src/less/: No matching DirectoryIndex (index.html,index.php,shopware.php) found, and server-generated directory index forbidden by Options directive, referer: https://ds-sportwagen-store.de/web/cache/1711022153_695ebeb379e1d12adfaf83d7568f879c.css
[Thu Mar 21 12:27:00.776250 2024] [autoindex:error] [pid 65110] [client 80.108.87.134:0] AH01276: Cannot serve directory /var/www/vhosts/ds-sportwagen-store.de/httpdocs/custom/plugins/SnapsSnapstrgOneProfessional/Resources/Themes/Frontend/SnapstrgOneProfessional/frontend/_public/src/less/: No matching DirectoryIndex (index.html,index.php,shopware.php) found, and server-generated directory index forbidden by Options directive, referer: https://ds-sportwagen-store.de/ferrada-wheels/
[Thu Mar 21 12:28:03.175028 2024] [autoindex:error] [pid 66193] [client 176.95.179.84:0] AH01276: Cannot serve directory /var/www/vhosts/ds-sportwagen-store.de/httpdocs/custom/plugins/SnapsSnapstrgOneProfessional/Resources/Themes/Frontend/SnapstrgOneProfessional/frontend/_public/src/less/: No matching DirectoryIndex (index.html,index.php,shopware.php) found, and server-generated directory index forbidden by Options directive, referer: https://ds-sportwagen-store.de/web/cache/1711022153_695ebeb379e1d12adfaf83d7568f879c.css
[Thu Mar 21 12:49:05.020469 2024] [autoindex:error] [pid 71534] [client 87.140.97.227:0] AH01276: Cannot serve directory /var/www/vhosts/ds-sportwagen-store.de/httpdocs/custom/plugins/SnapsSnapstrgOneProfessional/Resources/Themes/Frontend/SnapstrgOneProfessional/frontend/_public/src/less/: No matching DirectoryIndex (index.html,index.php,shopware.php) found, and server-generated directory index forbidden by Options directive, referer: https://ds-sportwagen-store.de/web/cache/1711022153_695ebeb379e1d12adfaf83d7568f879c.css
[Thu Mar 21 12:49:41.122265 2024] [autoindex:error] [pid 65107] [client 87.140.97.227:0] AH01276: Cannot serve directory /var/www/vhosts/ds-sportwagen-store.de/httpdocs/custom/plugins/SnapsSnapstrgOneProfessional/Resources/Themes/Frontend/SnapstrgOneProfessional/frontend/_public/src/less/: No matching DirectoryIndex (index.html,index.php,shopware.php) found, and server-generated directory index forbidden by Options directive, referer: https://ds-sportwagen-store.de/web/cache/1711022153_695ebeb379e1d12adfaf83d7568f879c.css
[Thu Mar 21 12:49:42.551806 2024] [autoindex:error] [pid 65106] [client 80.187.113.55:0] AH01276: Cannot serve directory /var/www/vhosts/ds-sportwagen-store.de/httpdocs/custom/plugins/SnapsSnapstrgOneProfessional/Resources/Themes/Frontend/SnapstrgOneProfessional/frontend/_public/src/less/: No matching DirectoryIndex (index.html,index.php,shopware.php) found, and server-generated directory index forbidden by Options directive, referer: https://ds-sportwagen-store.de/
Das sagt der Server error_log
Ich soll mich einloggen und nach dem Login ist es eine weisse Seite
Ähm das ist von 2021 :slight_smile: Müsstest schauen was zeitlich zur Migration passt.
Das ist von dem Jahr Donnerstag März 21 12:49 Uhr 2024 :slight_smile:
2021 gab es den Shop noch nicht :slight_smile:
Ah Mensch, brauch Urlaub :slight_smile: Aber die Fehlermeldungen beziehen sich nicht auf die Migration.
Die Fehler deuten auf ein Problem mit dem Plugin/Theme SnapsSnapstrgOneProfessional hin. Kannst du das mal deaktivieren?
Das ist wirklich zum Haare raufen… Gibt es eine Lösung wie ich das „gelöschte“ Plugin da raus bekomme?
Neu downloaden geht nicht da 5.7 nicht mehr unterstützt wird und Support gibt es da leider auch nicht mehr.
Da haben wir de Übeltäter. Hast du da ein Plugin „Blauband Newsletter“ (o.ä).? Da wird ein Feld erwartet, dass es in der DB nicht gibt. Entweder Plugin deaktivieren oder deinstallieren und neu installieren - damit eventuell das Feld neu angelegt wird.
Nein Blauband habe ich absolut nichts, ich habe auch alle Plugins deaktiviert und de Fehler kommt. Wie bekomme ich den Eintrag denn nun weg?
Die Fehlermeldung bedeutet, dass in der Datenbanktabelle ‚s_core_auth_attributes‘ keine Spalte mit dem Namen ‚blauband_email_newsletter‘ vorhanden ist, auf die zugegriffen werden kann. Die fehlende Spalte führt dazu, dass die SQL-Abfrage fehlschlägt. Um das Problem zu beheben, solltest Du überprüfen, warum die Spalte ‚blauband_email_newsletter‘ nicht vorhanden ist oder eben gleich das ganze Plugin deaktivieren, notfalls über die Datenbank!
Oder: Such mal in der DB nach »blauband«:
SELECT table_name
FROM information_schema.tables
WHERE table_schema = 'your_database_name' AND table_name LIKE 'blauband%';
Auch mal hier schauen, ob es das noch bei Dir gibt?
Also ich hab in der Datenbank nichts von Blauband gefunden, in den Einstellungen und bei den Plugins ist auch nichts von Blauband vorhanden.
Klar, in s_core_auth_attributes fehlt ja was!
Ich geh mal schwer davon aus, dass Ihr das Plugin mal installiert hattet und dann mal deinstalliert habt. Wahrscheinlich hat es dabei ein riesen Chaos in der DB hinterlassen!
Du musst über alle Plugins im Quellcode nach „blauband“ suchen - irgendwo muss das vorkommen. Oder im Core - was natürlich ganz hässlich wäre.
Ich würde aber mal tippen, dass es auf dieses Plugin zurückzuführen war/ist: E-Mails an Kunden schicken | Shopware Store
Alternativ wäre das Feld als tinyint in der Tabelle manuell anzulegen. Vielleicht reicht das schon…
Gefühlt wurde das in dem Shop einiges „herumgedoktert“ - was die Migration nicht gerade risikoärmer macht.
Ich werde das Plugin nun einfach mal installieren, vielleicht löst es das Problem ja.
Ehrlich gesagt weis ich nicht was in dem Shop gemacht wurde und was nicht, ich hab das als einen gefallen für einen Freund hier übernommen. Der alte „Webmaster“ hatte den Shop übergeben und selbst die Passwörter im nachhinein einfach geändert -.-
Installieren ist natürlich nicht mehr möglich wegen der Shopware Version…
