Why 2 theme plugins affect each other when used on different sales channels ?
I have two sales channels for different domains. And I also have 2 themes, one for each of them. It seems that when I enable the theme plugin, it starts to affect the designs even if it is not assigned to any sales channel. How to prevent that from happening ?
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski “Moritz Naczenski”)‍ Do you know why the scss files are only working on corresponding sales channels, but the twig files affect both of the sales channels ?
Sounds like a question for the support. But normally only the assigned themes will be losded.
The scss files are not loaded wrongly, just only the twig templates. Does that have something to do with the where are located the twig files? in both theme plugins they are located under the directory src/Resources/views/storefront/
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski „Moritz Naczenski“)‍ do you know whom should I ask from support, is there anyone in forums?
Did you create the theme via shopware console?
Or how did you create the theme?
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski “Moritz Naczenski”)‍ I have created both of the themes by myself according the Shopware guide. For a single sales channel website they work as intended.
scss files are located in src/Resources/app/storefront/src/scss
The twig files are located under the directory src/Resources/views/storefront/(layout or block, etc.)
Below is the theme.json file:
    "name": "IluDesign Theme",
    "author": "David Sargsyan",
    "previewMedia": "storefront/dist/assets/Ilu_Design_logo.png",
    "style": [
      "app/storefront/src/scss/overrides.scss",
      "@Storefront",
      "app/storefront/src/scss/base.scss"
    "views": [
      "@Storefront",
      "@Plugins",
      "@DasIluDesignTheme"
    "script": [
        "@Storefront",
        "app/storefront/dist/storefront/js/navigation.js"
    "config": {
      "fields": {
        "sw-color-brand-primary": {
          "value": "#a9a9a9"
    "asset": [
        "app/storefront/src/assets"
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski „Moritz Naczenski“)‍ is the directory where the twig files are located correct?
In here https://docs.shopware.com/en/shopware-platform-dev-en/theme-guide/twig-templates?category=shopware-platform-dev-en/theme-guide in some places it is sometimes mentioned that twig files should be under src/Resources/app/storefront/views/(layout or something else)/ and in some other places it is under /Resources/views/storefront/layout/header.
Which one is correct? Is the problem in directory structure or that I have not generated the plugin by shopware cli console ?
Show us your Bootstrap, it needs to implement ThemeInterface
otherwhise it is a plugin and will be loaded in every sales-channel, not only the assigned one.
It does, and the theme appears, I select the theme, but when I do so, the changes to the template, start to affect the other sales channel as well.
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski “Moritz Naczenski”)‍ the only difference I see here is the namespace, after the prefix I write a backslash .
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski “Moritz Naczenski”)‍ And yes it seems that the twig files behave as if they are in just a regular plugin, but I am not seeing the reason.
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski „Moritz Naczenski“)‍ is everything correct?
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski “Moritz Naczenski”)‍ we also opened a ticket but neither here nor there in account support we see an answer to this problem.
I can’t support you any more on this topic, since I don’t know where your issue comes from. For me, everything looks fine.
This forum is based ony the idea „users helping users“, so we can’t provide you any official support in this forum. If you created an official support request, you will get an anwer based on your subscription.
[@Moritz Naczenski](http://forum.shopware.com/profile/14574/Moritz Naczenski “Moritz Naczenski”)‍ we have got a response from the support, so others who may be interested as well, this is a known issue and will be fixed in 6.2
https://issues.shopware.com/issues/NEXT-7269
