Weiße Seite nach Installation
ich habe versucht, Shopware zu installieren - jedoch bekomme ich nach der Installation nur eine weiße Seite als /admin angezeigt.
Im Log steht
[2020-07-31 09:07:06] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for "GET /bundles/administration/static/img/favicon/favicon-16x16.png"" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php line 136 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0): No route found for \"GET /bundles/administration/static/img/favicon/favicon-16x16.png\" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php:136, Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code: 0): No routes found for \"/bundles/administration/static/img/favicon/favicon-16x16.png/\". at /var/www/clients/client3/web3/web/shop/vendor/symfony/routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)"} []
[2020-07-31 09:07:06] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for "GET /bundles/administration/static/img/favicon/favicon-32x32.png"" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php line 136 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0): No route found for \"GET /bundles/administration/static/img/favicon/favicon-32x32.png\" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php:136, Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code: 0): No routes found for \"/bundles/administration/static/img/favicon/favicon-32x32.png/\". at /var/www/clients/client3/web3/web/shop/vendor/symfony/routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)"} []
[2020-07-31 09:07:07] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for "GET /bundles/administration/static/img/favicon/android-chrome-192x192.png"" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php line 136 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0): No route found for \"GET /bundles/administration/static/img/favicon/android-chrome-192x192.png\" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php:136, Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code: 0): No routes found for \"/bundles/administration/static/img/favicon/android-chrome-192x192.png/\". at /var/www/clients/client3/web3/web/shop/vendor/symfony/routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)"} []
[2020-07-31 09:07:07] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for "GET /bundles/administration/static/img/favicon/android-chrome-256x256.png"" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php line 136 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0): No route found for \"GET /bundles/administration/static/img/favicon/android-chrome-256x256.png\" at /var/www/clients/client3/web3/web/shop/vendor/symfony/http-kernel/EventListener/RouterListener.php:136, Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code: 0): No routes found for \"/bundles/administration/static/img/favicon/android-chrome-256x256.png/\". at /var/www/clients/client3/web3/web/shop/vendor/symfony/routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)"} []
Ich weiß nicht, ob das auch das Problem ist. Aber ich komm einfach nicht weiter.
Ich nutze:
Debian 10, ISPConfig, PHP7.4
Installiert habe ich über git clone --branch=6.1 GitHub - shopware/production: Shopware 6 production template shop
Jemand eine Idee?
VG
Angelo
So einfach kann man Shopware afaik ned installieren. Hol dir das fertige Installationspaket per Download von deren Website oder bau dir ein eigenes mit dem Composer.
Danke für eure Antworten. Ja ich habe gesehen das ich 6.1 installiert habe obwohl es 6.2 gibt. Habe dann nochmal 6.2 probiert mit dem selben Ergebnis.
Die Domain zeigt auf Shop/Public.
Die Installation der Datenbank etc macht er ja auch über die Domain und es werden keine fehlenden Vorraussetzungen angezeigt. Aber nach der “Fertig” Meldung kommt nur noch ne weiße Seite.
Gruss
Angelo
Die Domain muss auf /public zeigen
Nicht Shop/public (Wenn Shop schon das Shop-Root (Stammverzeichnis) ist wei z.B. /httpdocs etc.)
Hast Du denn das Setup und install (wie auf dem hub beschrieben) komplett durchgeführt ?
