Was ist das denn für Einer? PHP Fatal error: Uncaught Symfony\Component\HttpFoundation\Exception\Co
Hi zusammen,
was ist das denn bitte für ein Fehler?
[18-Sep-2017 13:08:51 Europe/Berlin] PHP Fatal error: Uncaught Symfony\Component\HttpFoundation\Exception\ConflictingHeadersException: The request has both a trusted Forwarded header and a trusted Client IP header, conflicting with each other with regards to the originating IP addresses of the request. This is the result of a misconfiguration. You should either configure your proxy only to send one of these headers, or configure Symfony to distrust one of them. in /html/shopware/vendor/symfony/http-foundation/Request.php:822
Stack trace:
#0 /html/shopware/vendor/symfony/http-foundation/Request.php(852): Symfony\Component\HttpFoundation\Request->getClientIps()
#1 /html/shopware/engine/Shopware/Kernel.php(218): Symfony\Component\HttpFoundation\Request->getClientIp()
#2 /html/shopware/engine/Shopware/Kernel.php(180): Shopware\Kernel->transformSymfonyRequestToEnlightRequest(Object(Symfony\Component\HttpFoundation\Request))
#3 /html/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Reques in /html/shopware/vendor/symfony/http-foundation/Request.php on line 822
Vielen Dank und viele Grüße,
Chris
Siehe: Shopware Issuetracker
Sollte auf dem Server entsprechend konfiguriert werden, ansonsten kann das auch in SW gelöst werden (Kommentare)
