CRITICAL
Message: This action only admits post requests
Time: 2018-09-19T11:21:52.803617+0200
Channel: core
request: {
"uri": "/checkout/ajaxAddArticleCart?callback=jQuery224018976475632724477_1537348909106&sActionIdentifier=&sAddAccessories=&sAdd=SW10180&sQuantity=1&__csrf_token=fXAwPwQj3DUS2CuTvZeSlXbCYzrzEG&isXHR=1&_=1537348909107",
"method": "GET",
"query": {
"callback": "jQuery224018976475632724477_1537348909106",
"sActionIdentifier": "",
"sAddAccessories": "",
"sAdd": "SW10180",
"sQuantity": "1",
"__csrf_token": "fXAwPwQj3DUS2CuTvZeSlXbCYzrzEG",
"isXHR": "1",
"_": "1537348909107",
"module": "frontend",
"controller": "checkout",
"action": "ajaxAddArticleCart"
"post": []
session: No session data available
shopId: 1
shopName:
CRITICAL
Time: 2018-09-19T11:21:52.813530+0200
Channel: core
request: {
"method": "GET",
"query": {
"sAdd": "SW10180",
"sQuantity": "1",
"isXHR": "1",
"post": []
shopId: 1
shopName:
ERROR
Message: LogicException: This action only admits post requests in /engine/Shopware/Controllers/Frontend/Checkout.php:1454
Stack trace:
#0 /engine/Library/Enlight/Controller/Action.php(193): Shopware_Controllers_Frontend_Checkout->ajaxAddArticleCartAction()
#1 /engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight_Controller_Action->dispatch('ajaxAddArticleC...')
#2 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#3 /engine/Shopware/Kernel.php(215): Enlight_Controller_Front->dispatch()
#4 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#5 /engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#6 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(443): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#7 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(339): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#8 /engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(205): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 /shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#12 {main}
Time: 2018-09-19T11:21:52.814458+0200
Channel: core
request: {
"method": "GET",
"query": {
"sAdd": "SW10180",
"sQuantity": "1",
"isXHR": "1",
"post": []
shopId: 1
shopName:
Hallo ihr lieben,
nach einem Update unseres Shops, das ging normal wie immer vonstatten, gibt es eine komische Fehlermeldung.
Man kann kein Produkt mehr in den Warenkorb legen, rechts erscheint dann einfach eine weiße Seite mit dem Ladesymbol. Dachte erst es liegt an einem Plugin, wie Paypal oder so, aber auch nach löschen von Paypal geht es nicht.
Folgende Zeilen liefert das Fehlerlog per Mail:
Weiß jemand von Euch wo der Fehler zu suchen ist und uns von unserer Leitung runterheben?
Besten Dank
