Fehlermeldung seit 5.4.2 - checkout/addArticle/sAdd/002354
Hallo zuammen,
seit meinem heutigen Update auf die 5.4.2 kriege ich immer wieder Fehleremails wie die unten aufgeführte. Die Artikelnummer ist immer eine andere, aber der Rest bleibt identisch.
Hat jemand eine Idee wo ich hier anpacken könnte ?
Stefan
CRITICAL
Message:
This action only admits post requests
Time:
2018-04-21T10:51:00.433207+0200
Channel:
core
request:
    "uri": "/checkout/addArticle/sAdd/002354",
    "method": "GET",
    "query": {
        "module": "frontend",
        "controller": "checkout",
        "action": "addArticle",
        "sAdd": "002354"
    "post": []
session:
No session data available
shopId:
1
shopName:
XXXXXXX
CRITICAL
Message:
Time:
2018-04-21T10:51:00.472835+0200
Channel:
core
request:
    "method": "GET",
    "query": {
        "sAdd": "002354"
    "post": []
session:
shopId:
1
shopName:
XXXXXX
ERROR
Message:
exception 'LogicException' with message 'This action only admits post requests' in /var/www/XXXXX/XXXX/web/engine/Shopware/Controllers/Frontend/Checkout.php:499
Stack trace:
#0 [internal function]: Shopware_Controllers_Frontend_Checkout->addArticleAction()
#1 /var/www/XXXXX/XXXX/web/var/cache/production_201804030942/proxies/ShopwareControllersFrontendCheckoutProxy.php(7): call_user_func_array(Array, Array)
#2 /var/www/XXXXX/XXXX/web/engine/Library/Enlight/Hook/HookManager.php(187): Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy->executeParent('addArticleActio...', Array)
#3 /var/www/XXXXX/XXXX/web/var/cache/production_201804030942/proxies/ShopwareControllersFrontendCheckoutProxy.php(36): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy), 'addArticleActio...', Array)
#4 /var/www/XXXXX/XXXX/web/engine/Library/Enlight/Controller/Action.php(193): Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy->addArticleAction()
#5 /var/www/XXXXX/XXXX/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight_Controller_Action->dispatch('addArticleActio...')
#6 /var/www/XXXXX/XXXX/web/engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#7 /var/www/XXXXX/XXXX/web/engine/Shopware/Kernel.php(215): Enlight_Controller_Front->dispatch()
#8 /var/www/XXXXX/XXXX/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#9 /var/www/XXXXX/XXXX/web/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#10 /var/www/XXXXX/XXXX/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(443): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /var/www/XXXXX/XXXX/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(339): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /var/www/XXXXX/XXXX/web/engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /var/www/XXXXX/XXXX/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(205): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /var/www/XXXXX/XXXX/web/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 /var/www/XXXXX/XXXX/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#16 {main}
Time:
2018-04-21T10:51:00.473581+0200
Channel:
core
request:
    "method": "GET",
    "query": {
        "sAdd": "002354"
    "post": []
session:
shopId:
1
shopName:
XXXXX
der Fehler kommt entweder von deinem eingesetzten Theme oder einem eingesetzten Plugin, dass einen Button anbietet, der den Artikel in den Warenkorb über einen Direktlink versucht zu legen. Seit Shopware 5.4 kann man aber nur noch Artikel über einen POST-Request in den Warenkorb hinzufügen, siehe: Shopware 5 upgrade guide .
Die Fehlermeldung ist ja auch eindeutig:
Grüße
Sebastian
Hi zusammen,
vielen Dank die Rückmeldung. Zur besseren Identifizierung habe ich mal in die Zugriffslogs geschaut und dabei festgestellt, das diese Fehler vom Bingbot aus verursacht werden.  Ein spezielles Plugin konnte ich jetzt nicht dafür ausmachen.
Scheinbar versucht er was zu kaufen *lach*
207.46.13.10 - - [21/Apr/2018:05:19:57 +0200] "GET /checkout/addArticle/sAdd/40200710 HTTP/1.1" 503 11451 "-" "Mozilla/5.0 (compatible; bingbot/2.0; +http://www.bing.com/bingbot.htm)"
Grüße
Stefan
wie kann man die Bots aus dem Warenkorb aussperren? Oder macht es kein Sinn? Habe letzte Nacht 35 Emails erhalten mit dem Fehler. Scheinbar durch Googlebot
Ist eigentlich so vorkonfiguriert: shopware/index.tpl at 5.4 · shopware/shopware · GitHub
