div. Fehlermeldungen
ich habe in meinem Shop (Version 5.5.10) einige Fehlermeldungen:
exception ‚LogicException‘ with message ‚This action only admits post requests‘ in …/engine/Shopware/Controllers/Frontend/Checkout.php:528
Stack trace:
#0 …/engine/Library/Enlight/Controller/Action.php(192): Shopware_Controllers_Frontend_Checkout->addArticleAction()
#1 …/engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight_Controller_Action->dispatch(‚addArticleActio…‘)
#2 …/engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#3 …/engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#4 …/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#5 …/vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#6 …/engine/Shopware/Components/HttpCache/AppCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#7 …/vendor/symfony/http-kernel/HttpCache/HttpCache.php(420): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#8 …/vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#9 …/engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#10 …/vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#11 …/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 …/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#13 {main}
Könnte mir bitte jemand Tipps geben, wie ich diese beheben kann oder muss ich da die Profis ran lassen ?
Vielen herzlichen Dank für Eure Hilfe und Antworten
Gruss, martin
dein fehler „This action only admits post requests“ ist für addArticle in frontend.
also muss die frontend addArticle abfrage von GET ins POST abfrage geändert werden.
ich vermute eine alte theme oder plugin. (falls nicht eigene änderungen)
Vielen Dank für Deine Antwort.
Kann ich die Einstellung selber im Backend erledigen oder muss das im Code passieren?
Ich habe leider keine Programmierkenntnisse und müsste das sonst an einen Webdesigner /-programmierer abgeben.
der fehler ist 99% sicher in code, was aufm server (backend) liegt, aber von browser (frontend) ausgeführt wird.
um über shopware-backend (was in frontend läuft) die fehler verursacher zu finden, würde ich vorschlagen du deaktivierst einzelne plugins und schaust ob die fehler weg geht (cache leeren etc. nicht vergessen, falls nicht dev modus). wenn nicht, ändere mal auf die shopware responsive theme.
wenn es eins davon ist, schaue ob es updates hat und shopware 5.4+ unterstütz und dann diesen updaten.
wenn es keins davon ist, dann hat jemand wohl in deine shopware code was geändert…
ok - danke für die Infos (auch den Unterschied frontend und backend wusste ich noch nicht =)… Vielen Dank !!
Ich nutze übrigens das Responsive Theme.
Interessanterweise wird bei
Plugin-Manager > Installiert
gar nichts angezeigt.
Ich muss gestern allerdings meine 3 - 4 Plugins neu installieren, da der Plugin-Manager ein “Internal Server Error” angezeigt hat.
Dadurch konnte ich über die update-Funktion nichts updaten…
Eigentlich brauche ich nur das Paypal und das pdf-Rechnungs-Erstellungs-Plugin.
