Got a question regarding installation of shopweare 6.
I cannot go through full installation. Im stuck on last checkpoint with veryfing my domain.
I got the message
"Unauthorized
The taken action is unauthorized"
Can any1 help me out with this?
Screenshot with the issue
This error is usually displayed if the provided credentials for the Shopware Account are wrong, or when the domain is already registered. I recommend to contact our sales team if this issue persists.
Alternatively you can try to skip the step and restart the First run wizard later (Settings > System > First-run wizard): https://docs.shopware.com/en/shopware-6-en/first-steps/first-run-wizard
Have you solved it though ? otherwise I should open different support ticket
if its not get you authorized by wizard, just skip the wizard in last step. and then go to
Dashboard > Extentions > Store > Activate Store.
It will be fix.
