Versandarten und neue Versandart anlegen zeigt leere Seite
seit 6.2 kann ich weder neue Versandarten anlegen noch bestehende bearbeiten. Es kommt nur eine leere Seite. Keine Fehlermeldung
In der Entwicklerkonsole ist ein JS Fehler
vendors-node.js?15899573991367633:2 ReferenceError: saveFinish is not defined
    at s.eval (eval at qs (vendors-node.js?15899573991367633:2), :3:5127)
    at s.e._render (vendors-node.js?15899573991367633:2)
    at s.i (vendors-node.js?15899573991367633:2)
    at pn.get (vendors-node.js?15899573991367633:2)
    at new pn (vendors-node.js?15899573991367633:2)
    at vendors-node.js?15899573991367633:2
    at s.Cn.$mount (vendors-node.js?15899573991367633:2)
    at init (vendors-node.js?15899573991367633:2)
    at n (vendors-node.js?15899573991367633:2)
Ge @ vendors-node.js?15899573991367633:2
Ve @ vendors-node.js?15899573991367633:2
Ye @ vendors-node.js?15899573991367633:2
e._render @ vendors-node.js?15899573991367633:2
i @ vendors-node.js?15899573991367633:2
pn.get @ vendors-node.js?15899573991367633:2
pn @ vendors-node.js?15899573991367633:2
(anonymous) @ vendors-node.js?15899573991367633:2
Cn.$mount @ vendors-node.js?15899573991367633:2
init @ vendors-node.js?15899573991367633:2
u @ vendors-node.js?15899573991367633:2
p @ vendors-node.js?15899573991367633:2
e._update @ vendors-node.js?15899573991367633:2
e._init @ vendors-node.js?15899573991367633:2
Cn @ vendors-node.js?15899573991367633:2
value @ app.js?15899573994358820:1
value @ commons.js?1589957399199238:1
(anonymous) @ commons.js?1589957399199238:1
Promise.then (async)
(anonymous) @ admin:57
Show 26 more frames
DevTools failed to load SourceMap: Could not load content for https://www.xxx-24.de/797cea7978024b27e61f.worker.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for https://www.xxx-24.de/bundles/pickwaredhl/administration/js/pickware-dhl.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    at pn.run (vendors-node.js?15899573991367633:2)
    at dn (vendors-node.js?15899573991367633:2)
    at Array. (vendors-node.js?15899573991367633:2)
    at Ze (vendors-node.js?15899573991367633:2)
Es meckert hier Pickware an!?
Schuldigen gefunden…DHL Modul Version 0.3.3 ist das Problem. Deaktivere ich das Plugin…komme ich auch in den Versand.
Ich habe gerade das gleiche Problem, und es handelt sich dabei um das Plugin “DHL Versand” von Pickware - was aktuell noch nicht mit SW 6.2. kompatibel ist.
@Pickware‍ Habt ihr zufällig schon einen Zeitpunkt im Blick, wann es ein Update geben könnte?
Mfg
Sie arbeiten wohl schon dran. Ich hatte ein Ticket erstellt.
die zu Shopware 6.2 kompatible Version 1.0.0 unseres Plugins steht seit gestern Abend zur Verfügung.
das Pickware Team
