Hallo, auf einer SW 4.3.2 mit Varianten-Filter (1.0.6) gibt es einen Fehler, sobald eine Eigenschaft im Filter gewählt wir. Laut Log auf dem Server: [quote] GROUP BY a.datum, a.id OR’ at line 142’ in /culgjnrm/www.XXX.com/engine/Library/Zend/Db/Statement/Pdo.php:234 Stack trace: #0 /culgjnrm/www.XXX.com/engine/Library/Zend/Db/Statement.php(303): Zend_Db_Statement_Pdo->_execute(Array) #1 /culgjnrm/www.XXX.com/engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend_Db_Statement->execute(Array) #2 /culgjnrm/www.XXX.com/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(’\n SE…’, Array) #3 /culgjnrm/www.XXX.com/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(75): Zend_Db_Adapter_Pdo_Abstract->query(’\n SE…’, Array) #4 /culgjnrm/www.XXX.com/engine/Library/Zend/Db/Adapter/Abstract.php(776): Enlight_Components_Db_Adapter_Pdo_Mysql->query(’\n SE…’, Array) #5 /culgjnrm/www.XXX.com/engine/core/class/sArticles.php(1151): Zend_Db_Adapter_Abstract->fetchAssoc(’\n SE…’) #6 /culgjnrm/www.XXX.com/engine/Shopware/Controllers/Frontend/Listing.php(165): sArticles->sGetArticlesByCategory(895) #7 [internal function]: Shopware_Controllers_Frontend_Listing->indexAction() #8 /culgjnrm/www.XXX.com/cache/proxies/ShopwareControllersFrontendListingProxy.php(11): call_user_func_array(Array, Array) #9 /culgjnrm/www.XXX.com/engine/Library/Enlight/Hook/HookManager.php(191): Shopware_Proxies_ShopwareControllersFrontendListingProxy->executeParent(‘indexAction’, Array) #10 /culgjnrm/www.XXX.com/cache/proxies/ShopwareControllersFrontendListingProxy.php(23): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_ShopwareControllersFrontendListingProxy), ‘indexAction’, Array) #11 /culgjnrm/www.XXX.com/engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersFrontendListingProxy->indexAction() #12 /culgjnrm/www.XXX.com/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘indexAction’) #13 /culgjnrm/www.XXX.com/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #14 /culgjnrm/www.XXX.com/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #15 /culgjnrm/www.XXX.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #16 /culgjnrm/www.XXX.com/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #17 /culgjnrm/www.XXX.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #18 /culgjnrm/www.XXX.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #19 /culgjnrm/www.XXX.com/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #20 /culgjnrm/www.XXX.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #21 /culgjnrm/www.XXX.com/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #22 /culgjnrm/www.XXX.com/shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #23 {main} {“uid”:“8605a50”} [/quote] Es wird ein Template von TAB10 eigesetzt.
