Hi Shopware Community,
We sell in our shop a lot of MP3 files. And we want to create a unique MP3 files for each order. In our former shop we use a Zend module (Zend_Media_Id3v2) to add a MP3 tag with a Encrypted Code which contains an orderID and a customerID.
For it, I created a Download plugin, and add a FrontendCheckoutSubscriber. You can see the code below :
define('DIR_FS_DOCUMENT_ROOT', 'custom/plugins/HomsymDownload/Subscriber/');
define('DIR_ZEND_FOLDER', 'custom/plugins/HomsymDownload/Subscriber/Zend/');
require 'custom/plugins/HomsymDownload/Subscriber/Zend/Media/Zend_Media_Id3v2.php';
require 'custom/plugins/HomsymDownload/Subscriber/Zend/Media/Id3/Frame/Encr.php';
class FrontendCheckoutSubscriber implements SubscriberInterface
return [
'Enlight_Controller_Action_PostDispatchSecure_Frontend_Checkout' => 'onControllerActionFrontendCheckoutFinishAction'
public function onControllerActionFrontendCheckoutFinishAction(\Enlight_Event_EventArgs $args)
/** @var $controller Enlight_Controller_Action */
$controller = $args->getSubject();
/** @var \Enlight_Controller_Request_Request $request */
$request = $controller->Request();
if ($request->getActionName() !== 'finish') {
return;
//Some code here
$id3 = new Zend\Media\Zend_Media_Id3v2($file);
//Some code here
I put a Zend folder I use in our former shop with all the files necessary. Here is the file tree of the folder custom/plugins/My_plugin/Subscriber :
When I go to the /checkout/finish page after ordering an esd file, I get this error message :
Fatal error : Cannot declare class Zend_Media_Id3v2, because the name is already in use in /home/www/custom/plugins/HomsymDownload/Subscriber/Zend/Media/Zend_Media_Id3v2.php on line 713
I did a research into the code of my website to see if the class was declared many times but I found only one declaration in /Zend/Media/Zend_Media_Id3v2.php. I’ve also checked that there were only require_once in the files of the modules. So, I don’t understand why it says that the class is already declared.
You can also fing a Zend folder archive here : https://files.fm/f/yk4kt8br
Does someone have a explanation for that error ? Thanks !
