2017/10/18 09:13:21 [error] 4554#4554: *345794 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Error: Call to a member function getBaseUrl() on null in /var/www/clients/client367/web1054/web/var/cache/production_201709190948/templates/frontend_Themename_de_DE_1_secure/a1/0e/f1/a10ef1c1abe1f5d492c7e8b704bc3850b0a50a22.snippet.index.tpl.php:431
Stack trace:
#0 /var/www/clients/client367/web1054/web/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(180): content_59e68c69eb0344_88965801(Object(Enlight_Template_Default))
#1 /var/www/clients/client367/web1054/web/engine/Library/Enlight/View/Default.php(276): Smarty_Internal_TemplateBase->fetch()
#2 /var/www/clients/client367/web1054/web/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#3 /var/www/clients/client367/web1054/web/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#4 /var/www/clie" while reading response header from upstream, client: 66.249.75.215, server: domain.de, request: "GET /widgets/Listing/ajaxListing HTTP/1.1", upstream: "fastcgi://unix:/var/lib/php5-fpm/web1054.sock:", host: "www.domain.de"
Ein mit 5.3.3 betriebener Shop, der einen Tag lang fehlerfrei lief, produziert plötzlich im Errorlog obenstehenden Fehler. Alsbald man im Backend den ThemeManager aufrufen möchte. Meldet dieser Fehler 0 - bei den Themes wurde nichts verändert. Beim Aufruf des Thememanagers findet man folgenden Fehler im Errorlog:
2017/10/18 11:08:04 [error] 4553#4553: *417190 FastCGI sent in stderr: "PHP message: PHP Fatal error: Cannot declare class Shopware\Themes\Themename\Theme, because the name is already in use in /var/www/clients/client367/web1054/web/themes/Frontend/Themename/Theme.php on line 0" while reading response header from upstream, client: 87.145.85.219, server: domain.de, request: "GET /backend/Theme/list?_dc=1508317684422&page=1&start=0&limit=20&group=%5B%7B%22property%22%3A%22version%22%2C%22direction%22%3A%22DESC%22%7D%5D&sort=%5B%7B%22property%22%3A%22version%22%2C%22direction%22%3A%22DESC%22%7D%5D HTTP/1.1", upstream: "fastcgi://unix:/var/lib/php5-fpm/web1054.sock:", host: "www.domain.de", referrer: "https://www.domain.de/backend/"
Interpretiere ich diesen Logeintrag richtig, würde es bedeuten, dass es das Theme zweimal gibt - als Duplette, aber dem ist nicht so
Wer weiß rat oder wo kann ich nach der Ursache suchen?
