Updatefehler 6.4.20 --> 6.5.1: SQLSTATE[HY000]: General error: 1901
Hallo Community,
vielleicht kann jemand helfen. Versuche gerade (zum Glück auf dem Testsystem) von der 6.4.20 auf die 6.5.1 upzudaten.
Leider bekomme ich Datenbankfehler und habe keine Ahnung wie ich die beheben kann:
Get collection for identifier: "core"
migrate Migrations
  0/31 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░]   0% < 1 sec/< 1 sec 119.0 MiB09:48:16 ERROR     [app] Migration: "Shopware\Core\Migration\V6_5\Migration1675082889DropUnusedTables" failed: "An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1901 Function or expression 'variant_listing_config' cannot be used in the CHECK clause of `variant_listing_config`"
Das Ganze wiederholt sich unten im Log dann noch mehrfach:
Exception trace:
  at /www/htdocs/w0178bf0/shop_staging/vendor/shopware/core/Framework/Migration/Command/MigrationCommand.php:167
 Shopware\Core\Framework\Migration\Command\MigrationCommand->runMigrationForIdentifier() at /www/htdocs/w0178bf0/shop_staging/vendor/shopware/core/Framework/Migration/Command/MigrationCommand.php:102
 Shopware\Core\Framework\Migration\Command\MigrationCommand->execute() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/console/Command/Command.php:326
 Symfony\Component\Console\Command\Command->run() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/console/Command/LazyCommand.php:76
 Symfony\Component\Console\Command\LazyCommand->run() at /www/htdocs/w0178bf0/shop_staging/vendor/shopware/core/Maintenance/System/Command/SystemUpdateFinishCommand.php:120
 Shopware\Core\Maintenance\System\Command\SystemUpdateFinishCommand->runMigrations() at /www/htdocs/w0178bf0/shop_staging/vendor/shopware/core/Maintenance/System/Command/SystemUpdateFinishCommand.php:85
 Shopware\Core\Maintenance\System\Command\SystemUpdateFinishCommand->execute() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/console/Command/Command.php:326
 Symfony\Component\Console\Command\Command->run() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/console/Application.php:1081
 Symfony\Component\Console\Application->doRunCommand() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/framework-bundle/Console/Application.php:91
 Symfony\Bundle\FrameworkBundle\Console\Application->doRunCommand() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/console/Application.php:320
 Symfony\Component\Console\Application->doRun() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/framework-bundle/Console/Application.php:80
 Symfony\Bundle\FrameworkBundle\Console\Application->doRun() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/console/Application.php:174
 Symfony\Component\Console\Application->run() at /www/htdocs/w0178bf0/shop_staging/vendor/symfony/runtime/Runner/Symfony/ConsoleApplicationRunner.php:54
 Symfony\Component\Runtime\Runner\Symfony\ConsoleApplicationRunner->run() at /www/htdocs/w0178bf0/shop_staging/vendor/autoload_runtime.php:29
 require_once() at /www/htdocs/w0178bf0/shop_staging/bin/console:15
In ExceptionConverter.php line 117:
  [Doctrine\DBAL\Exception\DriverException (1901)]
Irgend etwas scheint mit den Varianten in der DB nicht zu passen
Damit läuft der Shop dann natürlich nicht mehr:
An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'tax_rule.active_from' in 'field list'
Hat jemand Ideen, wie ich das beheben kann?
Ansonsten wäre für mich das Update erst mal unmöglich…
HILFE!
Vielen Dank an alle im Voraus!
Prüf’ mal ob in der .env in Zeile 22 COMPOSER_HOME nicht ein Pfad zu einer alten URL eingetragen ist. Das war bei einem unserer Projekte die Ursache / Lösung.
Du benutzt MariaDB, richtig?
jupp MariaDB. Das war auch der Fehler!
Habe über den Hoster auf anderen Server mit MariaDB 10.6 umziehen lassen.
Ich habe vergessen hier zu posten - sorry, macht man nicht :face_with_open_eyes_and_hand_over_mouth:
Gibt auch einen anderen post von einem andere TE dazu…
Sehe jetzt erst, dass du schon am 9.9. geschrieben hast. :sweat_smile:
Hauptsache es geht wieder. :slight_smile:
Ja, stimmt.
Für alle die hier drüber gestolpert sind:
Es gibt einen „bug“ in MariaDB 6.x der den Fehler auslöst. Beschrieben auch in diesem Post: Fehlermeldung Datenbank einspielen aus Datensicherung
Nach einem Update (z.B. beim Hoster) auf MariaDB 10.6.10 und höher ist der Fehler behoben.
Version 6.4.14.0 auf 6.4.20
Guten Morgen zusammen - wir haben jetzt MariaDB 10.11.7 im Einsatz und der Shop läuft immer noch auf diese Fehlermeldung:
Received the following error message:
An exception occurred while executing ‚ALTER TABLE product ADD COLUMN variant_listing_config JSON GENERATED ALWAYS AS (CASE WHEN display_parent IS NOT NULL OR main_variant_id IS NOT NULL OR configurator_group_config IS NOT NULL THEN (JSON_OBJECT( ‚displayParent‘, display_parent, ‚mainVariantId‘, LOWER(HEX(main_variant_id)) ,‚configuratorGroupConfig‘, JSON_EXTRACT(configurator_group_config, ‚$‘))) END) VIRTUAL‘: SQLSTATE[HY000]: General error: 1901 Function or expression ‚variant_listing_config‘ cannot be used in the CHECK clause of variant_listing_config
Response
{„valid“:false,„errorMsg“:"An exception occurred while executing 'ALTER TABLE product ADD COLUMN variant_listing_config JSON\n GENERATED ALWAYS AS (CASE WHEN display_parent IS NOT NULL OR main_variant_id IS NOT NULL OR configurator_group_config IS NOT NULL\n
@ [Kai_Becker]
Bei welchen Hoster bist du? Hostingpaket oder Server?
Für alle die noch auf Version < 6.5.0.0 festhängen
Wir konnten unseren Shop erst erfolgreich updaten nachdem wir MariaDB fest auf die Version 10.6.10 gesetzt haben.
Unter debian geht das wie folgt:
sudo add-apt-repository ‚deb [arch=amd64,arm64,ppc64el,s390x] Index of /mariadb-10.6.10/repo/ubuntu/ focal main main/debug‘
apt install mariadb-client-core-10.6=1:10.6.10+maria~ubu2004 mariadb-client-10.6=1:10.6.10+maria~ubu2004 mariadb-server-10.6=1:10.6.10+maria~ubu2004 mariadb-server-core-10.6=1:10.6.10+maria~ubu2004
Wir sind jetzt auf Shopware 6.5.8.7.
Shopware stellt für dieses Problem in den Update-Migrationen der Shopware Version 6.5.6.0 eine Lösung bereit.
(Quelle)
Für ältere Shopware-Instanzen kann die Migration von 6.5.6.0 bereits im Vorfeld ausgeführt werden, damit der Fehler bei dem Update auf 6.5 nicht entsteht.
Wir haben hierzu einen Guide in unserem Hilfecenter bereitgestellt:
Shopware 6.5 - Function or Expression ‚variant_listing_config‘ cannot be used in the CHECK clause
Ich hoffe, ich konnte damit weiterhelfen. :blush:
Liebe Grüße
Marius
