Hallo Leute,
schon mehrere Male das Update von 6.6.7.1 aus 6.6.8.0 einzuspielen.
Bekomme immer den selben Fehler:
PHP Warning:  Module "curl" is already loaded in Unknown on line 0
PHP Warning:  Module "gd" is already loaded in Unknown on line 0
PHP Warning:  Module "intl" is already loaded in Unknown on line 0
Run Update preparations
> pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
> pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.013 seconds
Analyzed 1001 packages to resolve dependencies
Analyzed 11668 rules to resolve dependencies
Lock file operations: 2 installs, 4 updates, 0 removals
Installs: pentatrion/vite-bundle:v7.0.5, async-aws/core:1.22.1
Updates: shopware/core:v6.6.8.0, shopware/administration:v6.6.8.0, shopware/elasticsearch:v6.6.8.0, shopware/storefront:v6.6.8.0
  - Locking async-aws/core (1.22.1)
  - Locking pentatrion/vite-bundle (v7.0.5)
  - Upgrading shopware/administration (v6.6.7.1 => v6.6.8.0)
  - Upgrading shopware/core (v6.6.7.1 => v6.6.8.0)
  - Upgrading shopware/elasticsearch (v6.6.7.1 => v6.6.8.0)
  - Upgrading shopware/storefront (v6.6.7.1 => v6.6.8.0)
Writing lock file
Installing dependencies from lock file (including require-dev)
> pre-operations-exec: Symfony\Flex\Flex->recordOperations
Package operations: 2 installs, 4 updates, 0 removals
  - Upgrading shopware/core (v6.6.7.1 => v6.6.8.0): Extracting archive
  - Installing pentatrion/vite-bundle (v7.0.5): Extracting archive
  - Upgrading shopware/administration (v6.6.7.1 => v6.6.8.0): Extracting archive
  - Installing async-aws/core (1.22.1): Extracting archive
  - Upgrading shopware/elasticsearch (v6.6.7.1 => v6.6.8.0): Extracting archive
  - Upgrading shopware/storefront (v6.6.7.1 => v6.6.8.0): Extracting archive
> post-package-update: Symfony\Flex\Flex->enableThanksReminder
> post-package-install: Symfony\Flex\Flex->recordFlexInstall
Generating optimized autoload files
> post-autoload-dump: Symfony\Component\Runtime\Internal\ComposerPlugin->updateAutoloadFile
102 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
> post-update-cmd: Symfony\Flex\Flex->update
What about running composer global require symfony/thanks && composer thanks now?
This will spread some 💖  by sending a ★  to the GitHub repositories of your fellow package maintainers.
Symfony operations: 1 recipe (d21d8622de68aca01f8499f4c8344512)
  - Configuring pentatrion/vite-bundle (>=6.5): From github.com/shopware/recipes:main
    Enabling the package as a Symfony bundle
No security vulnerability advisories found.
Symfony operations: 18 recipes (804bb84cea075ad14af2662511f19b16)
  - Configuring symfony/flex (>=1.0): From github.com/symfony/recipes:main
    Copying files from recipe
      Created "./.env"
  - Configuring symfony/framework-bundle (>=6.4): From github.com/shopware/recipes:main
      Created "./config/services.yaml"
      Created "./src/Controller/.gitignore"
  - Configuring nyholm/psr7 (>=1.0): From github.com/shopware/recipes:main
      Created "./config/packages/nyholm_psr7.yaml"
  - Configuring shopware/administration (>=6.6): From github.com/shopware/recipes:main
      Created "./bin/build-administration.sh"
      Created "./bin/watch-administration.sh"
  - Configuring shopware/core (>=6.6): From github.com/shopware/recipes:main
      Created "./bin/.htaccess"
      Created "./bin/build-js.sh"
      Created "./bin/ci"
      Created "./bin/console"
      Created "./bin/functions.sh"
      Created "./config/jwt/.gitignore"
      Created "./custom/.htaccess"
      Created "./custom/apps/.gitignore"
      Created "./custom/plugins/.gitignore"
      Created "./custom/static-plugins/.gitignore"
      Created "./files/.htaccess"
      Created "./public/.htaccess.dist"
      Created "./public/index.php"
      Created "./public/maintenance.html"
      Created "./var/.htaccess"
      Created "./.htaccess"
    Adding environment variable defaults
    Setting parameters
    Adding entries to .gitignore
  -  IGNORING  shopware/core (>=6.6): From github.com/shopware/recipes:main
    Adding Docker Compose definitions to "./compose.yaml"
    Adding Docker Compose definitions to "./compose.override.yaml"
    Docker Compose definitions have been modified. Please run "docker compose up --build" again to apply the changes.
  - Configuring shopware/elasticsearch (>=6.6): From github.com/shopware/recipes:main
    Setting parameters
  - Configuring shopware/storefront (>=6.6): From github.com/shopware/recipes:main
      Created "./bin/build-storefront.sh"
      Created "./bin/watch-storefront.sh"
  - Configuring symfony/console (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/debug-bundle (>=5.3): From github.com/shopware/recipes:main
  - Configuring symfony/lock (>=5.2): From github.com/symfony/recipes:main
      Created "./config/packages/lock.yaml"
  - Configuring symfony/mailer (>=4.3): From github.com/shopware/recipes:main
  - Configuring symfony/messenger (>=6.0): From github.com/shopware/recipes:main
  - Configuring symfony/monolog-bundle (>=3.3): From github.com/shopware/recipes:main
  - Configuring symfony/routing (>=6.4): From github.com/shopware/recipes:main
      Created "./config/routes.yaml"
  - Configuring symfony/translation (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/twig-bundle (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/validator (>=5.3): From github.com/shopware/recipes:main
 Files have been reset to the latest version of the recipe.
  * Use git diff to inspect the changes.
    Not all of the changes will be relevant to your app: you now
    need to selectively add or revert them using e.g. a combination
    of git add -p and git checkout -p
  * Use git checkout . to revert the changes.
    New (untracked) files can be inspected using git clean --dry-run
    Add the new files you want to keep using git add
    then delete the rest using git clean --force
LogicException {#96
  #message: "Trying to register two bundles with the same name "PentatrionViteBundle"."
  #code: 0
  #file: "/var/www/vhosts/schwimm.store/httpdocs/vendor/symfony/http-kernel/Kernel.php"
  #line: 342
  trace: {
    /var/www/vhosts/schwimm.store/httpdocs/vendor/symfony/http-kernel/Kernel.php:342 { …}
    /var/www/vhosts/schwimm.store/httpdocs/vendor/shopware/core/Kernel.php:176 { …}
    /var/www/vhosts/schwimm.store/httpdocs/bin/console:54 {
      {closure}
      › $application = new Application($kernel);
      › $kernel->boot();
    /var/www/vhosts/schwimm.store/httpdocs/vendor/autoload_runtime.php:24 { …}
    /var/www/vhosts/schwimm.store/httpdocs/bin/console:17 { …}
2024-11-08T20:14:36+00:00 [info] User Deprecated: The "url" connection parameter is deprecated. Please use Doctrine\DBAL\Tools\DsnParser to parse a database url before calling Doctrine\DBAL\DriverManager. (DriverManager.php:257 called by DriverManager.php:173, https://github.com/doctrine/dbal/pull/5843, package doctrine/dbal)
2024-11-08T20:14:36+00:00 [info] User Deprecated: Not configuring a schema manager factory is deprecated. Use Doctrine\DBAL\Schema\DefaultSchemaManagerFactory which is going to be the default in DBAL 4. (Connection.php:222 called by DriverManager.php:197, https://github.com/doctrine/dbal/issues/5812, package doctrine/dbal)
2024-11-08T20:14:36+00:00 [critical] Uncaught Exception: Trying to register two bundles with the same name "PentatrionViteBundle".
Was sagt mir das?
VG R.
