Hi
When I am trying to download a „Cancellation bill“ from admin  order details I am getting the following error and the file is not downloading
{"errors":[{"status":"400","code":"DOCUMENT__GENERATION_ERROR","title":"Bad Request","detail":"Unable to generate document. Only versioned orders can be used for document generation.","meta":{"parameters":[]}}]}
What does that mean? How to download the file?
              It is a Shopware bug and the fix is available only in 6.4.0.0 which we cannot use in production.
So please edit the core file vendor/shopware/core/Checkout/Document/DocumentService.php
Replace the file function validateVersion with the following content
private function validateVersion(DocumentEntity $document, Context $context): void
    if ($document->getOrderVersionId() === Defaults::LIVE_VERSION) {
        // Only versioned orders can be used for document generation.
        $orderVersionId = $this->orderRepository->createVersion($document->getOrderId(), $context);
        $document->setOrderVersionId($orderVersionId);
        $this->documentRepository->update(
                    'id' => $document->getId(),
                    'orderVersionId' => $orderVersionId,
            $context
and also replace its function call with $this->validateVersion($document, $context);
There is no other solution for live site users. This is not good at all!
