Theme-Manager spuckt folgende Fehlermeldung aus wenn er geöffnet wird. Lösungsvorschläge?
Unable to load template snippet ‘backend/theme/view/detail/containers/tab.js’ in 'snippet:string:{include file=“backend/theme/model/theme.js”}
{include file=“backend/theme/model/element.js”}
{include file=“backend/theme/model/config_value.js”}
{include file=“backend/theme/model/layout.js”}
{include file=“backend/theme/model/config_set.js”}
{include file=“backend/theme/model/settings.js”}
{include file=“backend/theme/view/list/window.js”}
{include file=“backend/theme/view/list/theme.js”}
{include file=“backend/theme/view/list/extensions/info.js”}
{include file=“backend/theme/view/detail/theme.js”}
{include file=“backend/theme/view/detail/window.js”}
{include file=“backend/theme/view/create/window.js”}
{include file=“backend/theme/view/config_sets/window.js”}
{include file=“backend/theme/view/detail/containers/tab.js”}
{include file=“backend/theme/view/detail/containers/tab_panel.js”}
{include file=“backend/theme/view/detail/containers/field_set.js”}
{include file=“backend/theme/view/detail/fields/suffix.js”}
{include file=“backend/theme/view/detail/fields/pixel_field.js”}
{include file=“backend/theme/view/detail/fields/checkbox_field.js”}
{include file=“backend/theme/view/detail/fields/color_picker.js”}
{include file=“backend/theme/view/detail/fields/date_field.js”}
{include file=“backend/theme/view/detail/fields/em_field.js”}
{include file=“backend/theme/view/detail/fields/media_selection.js”}
{include file=“backend/theme/view/detail/fields/percent_field.js”}
{include file=“backend/theme/view/detail/fields/text_area_field.js”}
{include file=“backend/theme/view/detail/fields/text_field.js”}
{include file=“backend/theme/view/detail/fields/select_field.js”}
{include file=“backend/theme/view/settings/window.js”}
{include file=“backend/theme/view/settings/settings.js”}
{include file=“backend/theme/store/theme.js”}
{include file=“backend/theme/store/config_sets.js”}
{include file=“backend/theme/controller/list.js”}
{include file=“backend/theme/controller/detail.js”}
{include file=“backend/theme/controller/settings.js”}’ in Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(NULL, NULL, NULL, NULL, false, false, true)
 #1 var/cache/production\_201603220913/templates/backend\_de\_DE\_67bb8/cd/ea/10/cdea10031211c21ac8d00ba2e3250f46a7316d69.snippet.3ad0127075184592f4b71961b1aa7367692855ea.php(48): Smarty\_Internal\_Template-\>getSubTemplate('backend/theme/v...', NULL, 'backend\_de\_DE\_6...', NULL, NULL, Array, 0)
 #2 Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_57154594813595\_45447160(Object(Enlight\_Template\_Default))
 #3 Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch()
 #4 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
 #5 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
 #6 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
 #7 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
 #8 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
 #9 Enlight/Event/EventManager.php(213): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #10 Enlight/Controller/Action.php(201): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #11 Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('loadAction')
 #12 Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #13 Shopware/Kernel.php(153): Enlight\_Controller\_Front-\>dispatch()
 #14 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #15 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #17 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #18 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #19 {main}
steht doch da: Ioncube ist nicht installiert.
