Wenn ich den Theme-Manger laden will, erscheint ein Fenster “Shopware Fehler Reporter”. Darin ist eine Fehlermeldung in HTML angegeben. Wenn ich das Fenster schließe, versucht er noch ewig und erfolglos den Theme Manager zu laden. Was ist hier los?
Hier die Fehlermeldung, die darin erscheint
Unable to load template snippet 'backend/theme/view/create/window.js' in 'snippet:string:{include file="backend/theme/model/theme.js"}
{include file="backend/theme/model/element.js"}
{include file="backend/theme/model/config_value.js"}
{include file="backend/theme/model/layout.js"}
{include file="backend/theme/model/config_set.js"}
{include file="backend/theme/model/settings.js"}
{include file="backend/theme/view/list/window.js"}
{include file="backend/theme/view/list/theme.js"}
{include file="backend/theme/view/list/extensions/info.js"}
{include file="backend/theme/view/detail/theme.js"}
{include file="backend/theme/view/detail/window.js"}
{include file="backend/theme/view/create/window.js"}
{include file="backend/theme/view/config_sets/window.js"}
{include file="backend/theme/view/detail/containers/tab.js"}
{include file="backend/theme/view/detail/containers/tab_panel.js"}
{include file="backend/theme/view/detail/containers/field_set.js"}
{include file="backend/theme/view/detail/fields/suffix.js"}
{include file="backend/theme/view/detail/fields/pixel_field.js"}
{include file="backend/theme/view/detail/fields/checkbox_field.js"}
{include file="backend/theme/view/detail/fields/color_picker.js"}
{include file="backend/theme/view/detail/fields/date_field.js"}
{include file="backend/theme/view/detail/fields/em_field.js"}
{include file="backend/theme/view/detail/fields/media_selection.js"}
{include file="backend/theme/view/detail/fields/percent_field.js"}
{include file="backend/theme/view/detail/fields/text_area_field.js"}
{include file="backend/theme/view/detail/fields/text_field.js"}
{include file="backend/theme/view/detail/fields/select_field.js"}
{include file="backend/theme/view/settings/window.js"}
{include file="backend/theme/view/settings/settings.js"}
{include file="backend/theme/store/theme.js"}
{include file="backend/theme/store/config_sets.js"}
{include file="backend/theme/controller/list.js"}
{include file="backend/theme/controller/detail.js"}
{include file="backend/theme/controller/settings.js"}' in Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 Smarty/sysplugins/smarty_internal_template.php(286): Smarty_Internal_TemplateBase->fetch(NULL, NULL, NULL, NULL, false, false, true)
#1 var/cache/production_201605230943/templates/backend_de_DE_18ff4/cd/ea/10/cdea10031211c21ac8d00ba2e3250f46a7316d69.snippet.3ad0127075184592f4b71961b1aa7367692855ea.php(44): Smarty_Internal_Template->getSubTemplate('backend/theme/v...', NULL, 'backend_de_DE_1...', NULL, NULL, Array, 0)
#2 Smarty/sysplugins/smarty_internal_templatebase.php(180): content_57516a5bc88113_01937824(Object(Enlight_Template_Default))
#3 Enlight/View/Default.php(274): Smarty_Internal_TemplateBase->fetch()
#4 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#5 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#6 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#7 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#8 Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs))
#9 Enlight/Event/EventManager.php(213): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#10 Enlight/Controller/Action.php(201): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#11 Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('loadAction')
#12 Enlight/Controller/Front.php(226): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#13 Shopware/Kernel.php(153): Enlight_Controller_Front->dispatch()
#14 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#17 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#18 shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#19 {main}
